remark #7712 (again)
Norman_K_
Hi
I get an inappropriate remark #7712 from the following code
module A
    contains
    subroutine A_sub
        implicit none
        integer        :: i = 0
        namelist/this_out/i
        write(*, nml=this_out)
    end subroutine A_sub
end module A
program test_namelist
    use, non_intrinsic :: A
    call A_sub
    stop
end program
! Output during build:
!------ Build started: Project: test_namelist, Configuration: Debug|Win32 ------
!Compiling with Intel(R) Visual Fortran Compiler 17.0.4.210 [IA-32]...
!test_namelist.f90
!C:\Users\ces1nk\Dropbox\Shuttlebackup\Dept\Research\Programs\Test\test_namelist\test_namelist\test_namelist.f90(5): remark #7712:
!    This variable has not been used.
!The command line included the following switches (i.e. almost /warn: kitchen_sink)
!/nologo /debug:full /Od /warn:declarations /warn:unused /warn:truncated_source /warn:interfaces /module:"Debug\\" &
!/object:"Debug\\" /Fd"Debug\vc110.pdb" /traceback /check:bounds /check:stack /libs:dll /threads /dbglibs /c
but I do not get the remark #7712 from the following (same setup/switches etc
    call A_sub
    stop
    contains
    subroutine A_sub
        implicit none
        integer        :: i = 0
        namelist/this_out/i
end program
Both programs run fine but I do not like programs making inappropriate remarks!
Norman_K_
The second program has the use, non_intrinsic :: A commented out
Devorah_H_Intel
This issue is fixed in 18.0 compiler.
Norman_K_
Excellent, thanks.
