29642 Discussions
run-time error M6201: MATH - exp: DOMAIN error
rezanabavi
I am working with compaq visual fortran 6.6. my program was written in F77(some part)and F90(some part). I put together. the program is big and the run takes 1.5 days. when I run the program this error is appeared after 1 day execution.
- exp: DOMAIN error
and some time the following error:
**: DOMAIN error
Forum: Intel Visual Fortran Compiler for Windows
Posted: Nov 22, 8:52 AM [GMT -8]
Post Subject: Re: view source code after exception durig debugging
Post author: nijhuis
It is possible to set breakpoints on array elements. Click the "Edit", "Breakpoints" menu items and click the "Data" tab and you can enter an array element ( name with subscript(s) ) at which the debugger has to stop when changed. Breaks on allocatable array elements can only be set after allocation of the array.
Guus
anthonyrichards
New Contributor III
Math Error M6201
'function' : _DOMAIN error
An argument to the given function was outside the domain of legal input values for that function. For example, the following statements generate this error:
result = sqrt(-1.0) // C statement
result = SQRT(-1.0) ! FORTRAN statement
In your case, the 'function' is 'exp'. I do not know what the acceptable 'domain' is for the IA32 Fortran function 'exp', but in MS Visual Basic, If the value of number in exp(number)exceeds 709.782712893, an error occurs.
jimdempseyatthecove
Anthony,
I hope Steve or others at Intel will read my comments regarding this issue.
It would be nice if Intel and the other compiler an library writers would follow and documenta common programming practice that will aid the programmer in diagnosing such problems such as 'function': _DOMAIN error, and other program AB-END situations.
This is a relatively simple proceedure, which may be present, but not documented or easily found in the documentation.
The technique would be to provide a breakpoint symbol name of a null functionon which a user could place a break point and catch such problems early on (i..e. before the runtime systems nests down 10 levels into an error dump messaging system). Of particular annoyance is when a programmer (e.g. code in 3rd party library) contains a STOP statement. It would be nice if STOP, _DOMAIN error, etc... would all call the null function (with user break point) prior to mucking things in taking the program abort. This will give the user at least some means to better diagnose a problem. Other internal error conditions (file open, read/write, etc...) would also call the universal debug assist routine prior to dumping the error message.
This routine should also contain a meansfor the programmer to specify a return to application. e.g. from Dissassembly window the user could poke a return value to the null function which caused the program abort to abort (such as return from STOP). This provides the programmer the opportunity to better diagnose the problem.
Jim Dempsey
g_f_thomas
In CVF you can trap domain errors and the like via MATHERQQ. IVF doesn't have this facility.
Gerry
Jugoslav_Dujic
Valued Contributor II
g.f.thomas:
Because IVF now -- in my opinion correctly -- produces Infs and NaNs as results of math functions with out-of-domain arguments. You can debug these as normal floating-point exceptions (with an appropriate combination of /fpe:0 switches and properly set Debug/Exceptions).
g_f_thomas
JugoslavDujic:
Ditto for CVF. Additionally, because ofmatherr the f2003 IEEE floating point TR has long been available in CVF. It's still a no show in IVF. Anyways, the OP is using CVF, not IVF. I'd prefer to leave this oversulcated sward undisturbed.
Gerry
