search an ordered table
Mike896
Hi
Does anybody know if there is a function in IMSL that is able to search an ordered table.
I've found SRCH which can search a sorted vector for a given scalar and return its index.
However, I'd like to have a return of an index J such that given a value x is between arrayxx(J) and xx(J+1).
Thank you very much.
Mike
DavidWhite
Valued Contributor II
You can locate the position in the array using something like
J = MAXLOC(XX,MASK=XX.LT.X)
TimP
Why not look at 1 or 2 browser search hits? e.g. http://www.pdas.com/binsrch.htm
edr
Just write a quick binary search routine....since it is an ordered table that will probably be quicker (to execute) than most other methods.
Ed.R.
DavidWhite
Mike896
Quoting - David White
This is a very interesting method. Simple and work.
Thank you and all.
Mike
Jugoslav_Dujic
Quoting - Mike896
But not very efficient. Since your vector is already sorted, binary search would work much faster. For small datasets, however, simplicity is a virtue.
g_f_thomas
FWIT, a sorted list of N can be optimally searched in N1/2 steps via Grover's algorithm. However, the computer to do it has yet to be built.
Gerry
ArturGuzik
Mike,
from Numerical Recipes: "In most cases, when all is said and done, it is hard to do better than bisection,
which will find the right place in the table in about log_2(n) tries."
Take a look at routine "locate.f90". It does exactly what you're looking for. See Chapter 3, Interpolation and Extrapolation, specifically 3.4 "How to Search an Ordered Table" . Description and source code is on page 111 (of Fortran 77 edition), or 1045 (as function) in Fotran 90 Edition.
A.
Mike896
Yes, I have seen it. In fact, I used to use locate.f (mine is f77 version.But recently as I build the Numerical-Recipe library with IVF, there are lot of problems related to functions as an actual argument. Until now, I don't know how to solve this problem.
Therefore, I go to seek IMSL, but thereare no similar functions/subroutines.
thank you and all of you.
Mike
ArturGuzik
Mike,
I'm using this particular routine in several applications and it works perfectly. The F90 version is a function (unlike subroutine from F77). Do you have it? I saw that there is a newer NR (C++ edition only) available.
I have had a not-so-great experience with IMSL a few years back, so usually go the other way, trying to replace their "stuff" with something else.
A.
Mike896
Mine is f77 version. I don't have f90 version and C++ version.
Thank you for your reply.
Mike
ArturGuzik
Mike,
I'm not sure you need/want this but link to pdf (book and source code) is here so you can take a look. Section B3.
A.
Mike896
Thank you for your information.
I've found it and it works.
Mike
