serial and license error after updating the system
Xuchun_R_
My workstation was updated from win7 to win10 as required.  However, the serial numbers and license files for IMSL* Fortran Numerical Libraries for Windows* doesn't work when I reinstall it.  I bought these two serial numbers/licenses last year, they are perpetual licenses.  Please help to fix this problem, Thank you!  I need them ASAP.
Steve_Lionel
You should delete the first photo you attached, as it also shows your serial number. At this point you should open a ticket at the Online Service Center. There you can, in private, give the serial number and license file.
Steve_Lionel
Licensing questions now need to be reported in the Intel Online Service Center. Did you install the Fortran compiler first? When you say "doesn't work", what do you mean? Did you buy the IMSL from Intel?
Xuchun_R_
Can't install.  Shows an SN error or license error as attached.
Xuchun_R_
I bought it from Intel. Thanks,
Steve_Lionel
