static library for f77 files
Mike896
Hi
I build a static library from several *.f files.
After compiling it shows:
Error: If an external or dummy procedure name is used as an actual argument, its interface shall be explicit or it shall be explicitly declared to have the EXTERNAL attribute [DERIVS]
SUBROUTINE RKDUMB(VSTART,NVAR,X1,X2,NSTEP,DERIVS)
PARAMETER (NMAX=10)
COMMON /PATH/ XX(200),Y(10,200)
DIMENSION VSTART(NVAR),V(NMAX),DV(NMAX)
DO 13 K=1,NSTEP
CALL DERIVS(X,V,DV)
CALL RK4(V,DV,NVAR,X,H,V,DERIVS)
RETURN
END
Thank you very much
Mike
The compiler is correct in the error message. You should add:
EXTERNAL DERIVS
if you are passing it as a dummy argument. I can believe that older compilers would not detect this error.
EXTERNAL DERIVS
Mike896
Thank you very much. :)
Mike
