29488 Discussions
-staticlib option bug in Composer XE 2011 Update 7 for Mac OS X, aka 12.1.1.246
Ron_Green
bug in -staticlib option starting with Composer XE 2011 for Mac OS X Update 7, aka version 12.1.1.246. Affects both Intel C++ and Intel Fortran compilers.
Does not affect linux or Windows compilers, as this option is ONLY supported on Mac OS X platforms.
Knowledge Base article is here:
Afffected compilers: Intel C++ and Fortran Composer XE 2011 for Mac OS X Update 7, aka version 12.1.1.246
Background: The Intel Composer XE 2011 compilers for Mac OS X support the option -staticlib for compatibility with gcc. This option allows creation of a static library in one-step, taking a source file as input and producing a .a static library as output. This option worked in the Composer XE 2011 Update 6 compilers.
Scope: This option is ONLY supported on the Mac OS X platform. Thus, this bug is limited in scope to the Mac OS X compilers. this affects both the Intel C++ and Intel Fortran compilers for Mac OS X.
Symptom: Compiling with -staticlib causes the error:
Undefined symbols for architecture x86_64:
"_main", referenced from:
start in crt1.10.6.o
ld: symbol(s) not found for architecture x86_64
Examples:
C/C++:
cat foo.c
extern double pow(double, double);
double foo(double x, double y)
return pow(x, y);
$ icc -staticlib foo.c -o foo.a
Fortran:
cat subrout.f90
subroutine pow( x, y)
real (8) :: x,y
y = 2*x
end subroutine pow
$ ifort -staticlib subrout.f90 -o subrout.a
"_MAIN__", referenced from:
_main in for_main.o
ISSUE ID: DPD200175631
Ron_Green
This issue is fixed in the latest Composer XE 2013 Update 2 compiler.  Closing.
