strange warning with WRITE statement
Brian_Murphy
New Contributor II
I'm working on a console window application. The following statement writes three 4x4 matrices, one row at a time. DO JJ=1,4 WRITE(IOUT,'(3(4(G12.5,1X),4X))') & BEAR1%BR(I)%B(ISPD)%K(JJ,1:4), & BEAR1%BR(I)%B(ISPD)%C(JJ,1:4), & BEAR1%BR(I)%B(ISPD)%M(JJ,1:4) END DO This generates warnings in the console window as follows: forrtl: warning (402): fort: (1): In call to I/O Write routine, an array temporary was created for argument #1 The statement works as intended, but what is the warning for? What is argument #1? Pointers are used in the chain of derived types. Could that have something to with it? Brian in Austin, Texas
Brian_Murphy
New Contributor II
Grrr! How do I keep the forum web site from butchering the formatting of my postings?
mecej4
You can ignore the warning(s). If you are curious, see http://software.intel.com/en-us/forums/topic/297425 .
Brian_Murphy
New Contributor II
Thanks.  That explains it.  I think what happened was I had just turned on ALL for run-time error checking.  The WRITE'ing of matrix rows with implied loops evidently leads to the creation of temporary arrays, and thus the warning.
Did the request for
/check:arg_temp_created_except_for_write_statements_that_you_know_are_ok
ever get done?  That was 4 years ago.
Steven_L_Intel1
Nothing has been changed in this area.
As for inserting code, you can put it between tags as explained in the fourth bullet below the post composition window.
Brian_Murphy
New Contributor II
About the formatting.  I had a post ready to go, and I clicked on the Preview button, and it all got run together in one paragraph.
