29627 Discussions
syntax error: logical expression in sourced allocation
Ferdinand_T_
New Contributor II
today ifort 14.0.1 got me confused with the followign syntax error where I think I wrote legal code:
[fortran]
program p
    implicit none
    logical, allocatable :: flag
    ! allocation and assignment from logical expression
    allocate(flag)
    flag = .true. .or. .false.            ! OK
    ! sourced allocation from logical expression
    allocate(flag, source = (.true. .or. .false.))    ! OK
    allocate(flag, source =  .true. .or. .false. )    ! ERROR
end program
[/fortran]
Output:
error #5082: Syntax error, found '.' when expecting one of: * ) :: , <END-OF-STATEMENT> ; . (/ + - : ] /) ' ** / // > .LT. < ...
    allocate(flag, source = .true. .or. .false.)
Just out of curiosity: can somebody comment on this?
Best regards
Ferdinand
I think that's legal and will ask the developers to fix this.
Intel_C_19
I add a logical :: a,b in the statements, and change line 11 into "allocate(flag, source = a.or.b )"
then I get:
error #6866: Dotted string neither a defined operator nor a structure component [OR]
allocate(flag, source = a.or.b ) ! ERROR
error #8155: In an ALLOCATE statement the source expression in SOURCE= or MOLD= specifiers must be of the same type and kind type parameters as the object being allocated.
seems the compiler forget what is "or" here.....
Izaak_Beekman
New Contributor II
Perhaps I missed something, but don't you need to deallocate flag before reallocating it? This is certainly the case for allocatble arrays, and I beleive it applies to allocatable scalars as well. (Although, this isn't explicitly stated to be true for scalars in Modern Fortran Explained... AFAICT)
Ferdinand_T_
New Contributor II
Thanks, Steve.
@ heylouis,
Any logical operation (not only .or.) raises an error. Only a logical primary or a parenthesed expression is currently accepted in the source.
Izaak, yes, the code as shown would be an invalid double (or even triple) allocation, but the code does demonstrate the problem reported.
This problem has been fixed for a future release.
