29653 Discussions
syntax for copy-command inside Fortran
tropfen
is there a syntax inside fortran which works as a copy-command (like DELFILESQQ or RENAMEQQ). I can't use the SYSTEM-syntax because of blanks inside the file names.
If yes, please send a short example/description in your answer.
Thanks for help in advance
Frank
Les_Neilson
Valued Contributor II
OK. a very rough and ready solution :
Code:
use ifwinty
character*80 file1, file2
integer(BOOL) :: cp
logical :: ires
      interface
         integer function CopyFileA (file1,file2,res)
           !dec$ attributes stdcall, alias:'_CopyFileA@12' :: CopyFileA
           character*(*) :: file1 [reference]
           character*(*) :: file2 [reference]
           logical*4     :: res [reference]
         end function CopyFileA
      end interface
ires  = .false.
file1 = "first file.txt"C
file2 = "copy of first file.txt"C
cp = CopyFileA(file1, file2, ires)
Les
