29285 Discussions
syntax to distinguish between ivf and cvf inside select case
tropfen
i am looking for a syntax to distinguish between ivf and cvf inside a select case (or if .. then .. else) statement.
The syntax shall be placed inside a subroutine. The subroutine is placed inside a module which shall be used in cvf and ivf. [example for problematic source to use in both compilers is :inquire(directory=.., exits=..)]
Thanks in advance
Frank
joerg_kuthe
I don't know if there is a solution using standard Fortran statements like SELECT CASE or IF, but maybe using the compiler's metadirective helps you as well. Example:
!DEC$ IF DEFINED ($CVF)
put your Fortran source code for CVFhere
!cDEC$ ELSE
put your Fortran source code for IVFhere
!DEC$ ENDIF
Then add the variable$CVF to the "Predefined Preprocessor Symbols" (dialog "Project Settings" |"Fortran" tab).
Joerg Kuthe
www.qtsoftware.de
TimP
You can distinguish ranges of IVF versions at compile time by the predefined preprocessor macros __INTEL_COMPILER=nnnn
Lorri_M_Intel
In the "for what it's worth" category, CVF defined the macro _DF_VER, and (as Tim pointed out) ifort defines the macro __INTEL_COMPILER
It would be a simple matter to use these to conditionalize code for CVF vs Intel Fortran.
- Lorri
