the power function is serialized under Intel Fortran
mehdi__chinoune
I tried to use Intel Advisor to vectorise my program. and it tells me that the compiler con not vectorise some loops because it contain _powr8i4 which correspond to x**i (x:double precision and i:integer).
Why did not intel Fortran Compiler come with a vectorized version of _powr8i4 (or generally power function)?
and How to vectorise it (other than using MKL)?
NB: I did use the most aggressive optimization flags : /O3 /QxHost /Qipo /fp:fast=2
jimdempseyatthecove
For + powers, try:
    module foo
    contains
    !dir$ attributes vector : vectorlength(4) :: vpowr8i4
    elemental function vpowr8i4(baseIN, expIN) result(ret)
        implicit none
        real(8), intent(in) :: baseIN
        integer(4), intent(in) :: expIN
        real(8) :: base, ret
        integer(4) :: exp
        base = baseIn
        exp = expIN
        ret = 1.0_8
        do while(exp .ne. 0)
            if(IAND(exp,1) .ne. 0) ret = ret * base;
            exp = ishft(exp, -1)
            base = base * base
        end do
    end function vpowr8i4
    end module foo
    program test_vpowr8i4
    use foo
    implicit none
    integer, parameter :: arraySize = 1024
    !dir$ attributes align : 64 :: array,arrayOut
    real(8) :: array(arraySize)
    real(8) :: arrayOut(arraySize)
    integer :: i,exp
    do i=1,arraySize
        array(i) = i
    end do
    print *,"Enter exponent"
    read *,exp
    print *,"Break on this line in Release build"
    !dir$ simd
    do i=1,arraySize
        arrayOut(i) = vpowr8i4(array(i), exp)
    end do
    do i=1,10
        print *, array(i), arrayOut(i)
    end do
    end program test_vpowr8i4
 Enter exponent
3
   1.00000000000000        1.00000000000000
   2.00000000000000        8.00000000000000
   3.00000000000000        27.0000000000000
   4.00000000000000        64.0000000000000
   5.00000000000000        125.000000000000
   6.00000000000000        216.000000000000
   7.00000000000000        343.000000000000
   8.00000000000000        512.000000000000
   9.00000000000000        729.000000000000
   10.0000000000000        1000.00000000000
Press any key to continue . . .
Jim Dempsey
mehdi__chinoune
jimdempseyatthecove wrote:
For + powers, try:
    module foo
    contains
        implicit none
        integer(4) :: exp
        base = baseIn
        exp = expIN
        ret = 1.0_8
            base = base * base
        end do
    end module foo
    use foo
    implicit none
    integer :: i,exp
    do i=1,arraySize
        array(i) = i
    end do
    read *,exp
    !dir$ simd
    do i=1,arraySize
    end do
    do i=1,10
    end do
 Enter exponent
3
Jim Dempsey
Thank you, I know these tricks but I don't want to modify my code or to use extensions. I just asked if there is something i missed like flags or link ...
