I tried to use Intel Advisor to vectorise my program. and it tells me that the compiler con not vectorise some loops because it contain _powr8i4 which correspond to x**i (x:double precision and i:integer).
Why did not intel Fortran Compiler come with a vectorized version of _powr8i4 (or generally power function)?
and How to vectorise it (other than using MKL)?
NB: I did use the most aggressive optimization flags : /O3 /QxHost /Qipo /fp:fast=2
For + powers, try:
module foo contains !dir$ attributes vector : vectorlength(4) :: vpowr8i4 elemental function vpowr8i4(baseIN, expIN) result(ret) implicit none real(8), intent(in) :: baseIN integer(4), intent(in) :: expIN real(8) :: base, ret integer(4) :: exp base = baseIn exp = expIN ret = 1.0_8 do while(exp .ne. 0) if(IAND(exp,1) .ne. 0) ret = ret * base; exp = ishft(exp, -1) base = base * base end do end function vpowr8i4 end module foo program test_vpowr8i4 use foo implicit none integer, parameter :: arraySize = 1024 !dir$ attributes align : 64 :: array,arrayOut real(8) :: array(arraySize) real(8) :: arrayOut(arraySize) integer :: i,exp do i=1,arraySize array(i) = i end do print *,"Enter exponent" read *,exp print *,"Break on this line in Release build" !dir$ simd do i=1,arraySize arrayOut(i) = vpowr8i4(array(i), exp) end do do i=1,10 print *, array(i), arrayOut(i) end do end program test_vpowr8i4 Enter exponent 3 Break on this line in Release build 1.00000000000000 1.00000000000000 2.00000000000000 8.00000000000000 3.00000000000000 27.0000000000000 4.00000000000000 64.0000000000000 5.00000000000000 125.000000000000 6.00000000000000 216.000000000000 7.00000000000000 343.000000000000 8.00000000000000 512.000000000000 9.00000000000000 729.000000000000 10.0000000000000 1000.00000000000 Press any key to continue . . .
Jim Dempsey
jimdempseyatthecove wrote:
For + powers, try:
module foo contains !dir$ attributes vector : vectorlength(4) :: vpowr8i4 elemental function vpowr8i4(baseIN, expIN) result(ret) implicit none real(8), intent(in) :: baseIN integer(4), intent(in) :: expIN real(8) :: base, ret integer(4) :: exp base = baseIn exp = expIN ret = 1.0_8 do while(exp .ne. 0) if(IAND(exp,1) .ne. 0) ret = ret * base; exp = ishft(exp, -1) base = base * base end do end function vpowr8i4 end module foo program test_vpowr8i4 use foo implicit none integer, parameter :: arraySize = 1024 !dir$ attributes align : 64 :: array,arrayOut real(8) :: array(arraySize) real(8) :: arrayOut(arraySize) integer :: i,exp do i=1,arraySize array(i) = i end do print *,"Enter exponent" read *,exp print *,"Break on this line in Release build" !dir$ simd do i=1,arraySize arrayOut(i) = vpowr8i4(array(i), exp) end do do i=1,10 print *, array(i), arrayOut(i) end do end program test_vpowr8i4 Enter exponent 3 Break on this line in Release build 1.00000000000000 1.00000000000000 2.00000000000000 8.00000000000000 3.00000000000000 27.0000000000000 4.00000000000000 64.0000000000000 5.00000000000000 125.000000000000 6.00000000000000 216.000000000000 7.00000000000000 343.000000000000 8.00000000000000 512.000000000000 9.00000000000000 729.000000000000 10.0000000000000 1000.00000000000 Press any key to continue . . .Jim Dempsey
Thank you, I know these tricks but I don't want to modify my code or to use extensions. I just asked if there is something i missed like flags or link ...
