29282 Discussions
the result of last "break point"
Mike896
Hi
I am not familar to debugger (visual studio 2008).
When debugging, if I press "Navigate backward/forward", I thought it can bring me to the result of last "break point".
But it doesn't. How to show every previous result by using debugger?
Mike
onkelhotte
New Contributor II
Quoting - Mike896
Hi
Mike
AFAIK the debugger can only show the actual value of a variable. It would use a lot of memory, when you want to trace back every single value of all your variables since your program started.
What does "Navigate forward / backward" mean? I havent found that option in debugger.
When I want to trace a variable over a period of time, I write it into a text file to see the changes.
Markus
Mike896
Quoting - onkelhotte
Markus
Thank you very much for your reply.
"Navigate forward / backward" can be found in toolbar.
I've searched in Help. It seems not related to debugger.
Mike
