29649 Discussions
type-bound procedures with external subroutine argument
elwong
When I compile the attached code with ifort12.1.0, I get the error:
test.f90(32): error #8382: The dummy arguments of an overriding and overridden binding that correspond by position must have the same names. [TESTMOD0^EXT]
procedure :: init => t1init
compilation aborted for test.f90 (code 1)
I normally use gfortran4.6.2 and it's never complained about this sort of thing, so I've assumed it's legal. Seems like ifort names the external subroutine with the name of the module so it appears different in the two modules.
Any help would be appreciated. Thanks
subroutine ext ( i )
integer, intent(out) :: i
i = 0
end subroutine ext
module testMod0
type :: t0
integer :: i0
contains
procedure :: init
end type t0
contains
subroutine init ( myT, ext )
class(t0) :: myT
procedure() :: ext
write(6,*) ' 10 '
end subroutine init
end module testMod0
module testMod1
use testMod0, only : t0
type, extends(t0) :: t1
integer :: i1
contains
end type t1
contains
subroutine t1init ( myT, ext )
class(t1 ) :: myT
procedure() :: ext
write(6,*) ' 20 '
end subroutine t1init
end module testMod1
Thanks for the nice test case. I can reproduce the problem and it is indeed a bug in ifort. I have escalated this as issue DPD200176430. It appears to be triggered by having a procedure (or external) as an argument to the type-bound procedure, and having the ONLY clause. If you remove the ONLY on the use of testMod0, it compiles ok.
elwong
Thanks for the reply. It's good to know that removing the only will make it compile. I was worried I'd have to make some major change to my code to get it to work with ifort.
I expect this problem to be fixed in Update 9.
