- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Subscrever fonte RSS
- Destacar
- Imprimir
- Marcas:
- Intel® Fortran Compiler
Link copiado
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
The CASE-selector-block construct in Fortran allows the selector to be an initialization expression or even something such as
CASE (1, 2, 7, 10:17, 23)
You are not even required to use a SELECT construct. You can use a matrix, use binary search, or whatever you please, as long as your code does what IMSL wants it to.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
i am a new learner about IMSL and i also have a similar question here.
No.1 i write my FCN subroutine as following:
SUBROUTINE FCN1 (X, IACT, RESULT, IERR) INTEGER IACT REAL(KIND(1E0)) X(*), RESULT LOGICAL IERR ! SELECT CASE (IACT) CASE(0) RESULT = (X(1)-2.0E0)**2 + (X(2)-1.0E0)**2 CASE(1) RESULT = (X(1)-1)**2*(X(1))**2 !CASE(2) !RESULT = -(X(1)**2)/4.0E0 - X(2)**2 + 1.0E0 END SELECT RETURN END
and i call the NNLPF in my main program like this:
EXTERNAL FCN1 INTEGER::M, ME REAL(KIND(1E0)) FVALUE, X(5), XGUESS(5), XLB(5), XUB(5) M=1 ME=1 XLB = -HUGE(X(1)) XUB = HUGE(X(1)) CALL NNLPF (FCN1, M, ME, IBTYPE, XLB, XUB, X,IPRINT=1) !DO i =1,size(X) ! write(*,'(F4.0)')X(i) !END DO CALL WRRRN ('The solution is', X)
as you see,my object function is "min f=(x1-2)^2+(x2-1)^2" and i only have one equality constraint:(x1-1)^2*x1^2=0; the optimal solution i think is x1=1.0,x2=1.0,and the minimun f=1.0.
but the indicated result is x1=0.0,x2=1.0,min f =4.0,as show in the attachments.
i don't know why?
No.2 if i don't know the number of equality constraints and uneqaulity constraints, and even the size of variable X, or some other linear constraints bounds ,when i write my FCN subroutine. it just decided by input files read from the main program .then how can write my FCN subroutine? in other words, how can i pass the optimization dimension and the constraints bounds parameter to my FCN?
thanks a lot!
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
The majority of nonlinear constrained optimization solvers are local optimizers. Their success often depends on your giving them good starting values and well-behaved functions in the objective and constraint functions. In your case, you seem to seek a global optimum, yet you gave no starting guess for X(1:2). The IMSL manual states "A good initial starting point is very problem specific and should be provided by the calling program whenever possible. See optional argument XGUESS.". You can also help move the optimizer towards the region of the more desirable solution by specifying additional constraints. For example, try x1 >= 0.001.
What was the reason for specifying the constraint as [(x1 - 1) x2]2 = 0 instead of simply (x1 - 1) x2 = 0 ?
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
What was the reason for specifying the constraint as [(x1 - 1) x2]2 = 0 instead of simply [(x1 - 1) x2] = 0 ?
okay, your answer is very helpful! but what about the question NO.2
"if i don't know the number of equality constraints and uneqaulity constraints, and even the size of variable X, or some other linear constraints bounds ,when i write my FCN subroutine. it just decided by input files read from the main program .then how can write my FCN subroutine? in other words, how can i pass the optimization dimension and the constraints bounds parameter to my FCN?"
thanks very much!
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
In situations where the argument list (specified by IMSL for the user function FCN) is not adequate, you can supplement it by using module variables (or, in the old days, using COMMON blocks). Be aware, however, that hiding information from the optimization routine can often cause failure to obtain a solution.
Here is an example, which I constructed by extending the example given in the IMSL manual for NNLPF.
MODULE sharedvars IMPLICIT NONE INTEGER :: n, m = 2, me = 1, ibtype = 0 END PROGRAM xnnlpf USE nnlpf_int USE wrrrn_int USE sharedvars IMPLICIT NONE ! REAL fvalue REAL, ALLOCATABLE :: x(:), xguess(:), xlb(:), xub(:) INTEGER i EXTERNAL fcn ! READ (*, *) n ALLOCATE (x(n), xguess(n), xlb(n), xub(n)) xlb = -100 xub = 100 DO i = 1, n xguess(i) = 0.1*i END DO ! CALL nnlpf(fcn, m, me, ibtype, xlb, xub, x) ! CALL wrrrn('The solution is', x) DEALLOCATE (x, xguess, xlb, xub) END SUBROUTINE fcn(x, iact, result, ierr) USE sharedvars IMPLICIT NONE INTEGER iact, i REAL (kind(1E0)) x(n), & ! N is taken from SHAREDVARS result LOGICAL ierr ! SELECT CASE (iact) CASE (0) result = 0 DO i = 1, n result = result + (x(i)+i-3)**2 END DO CASE (1) result = x(1) - 2.0E0*x(2) + 1.0E0 CASE (2) result = -(x(1)**2)/4.0E0 - x(2)**2 + 1.0E0 END SELECT RETURN END
Compile and run it for various values on n, such as n = 2, n=3, n=4, etc.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
If you contain the FCN routine inside your program it gives scope to program variables inside FCN and also provides an explicit interface to FNC so that its argument declarations can be checked against the requirements. Now we dont need the EXTERNAL statement. Note that you did not declare or set IBTYPE.
PROGRAM TEST use NNLPF_INT INTEGER IBTYPE, M, ME REAL(KIND(1E0)) FVALUE, X(5), XGUESS(5), XLB(5), XUB(5) M=1 ME=1 XLB = -HUGE(X(1)) XUB = HUGE(X(1)) CALL NNLPF (FCN1, M, ME, IBTYPE, XLB, XUB, X,IPRINT=1) !DO i =1,size(X) ! write(*,'(F4.0)')X(i) !END DO CALL WRRRN ('The solution is', X) CONTAINS SUBROUTINE FCN1(X, IACT, RESULT, IERR) INTEGER, intent(in) :: IACT REAL(KIND(1E0)), INTENT(IN) :: X(*) REAL(KIND(1E0)), INTENT(OUT) :: RESULT LOGICAL, INTENT(OUT) :: IERR WRITE(*), XLB ! Check we can see variables in scope of our container SELECT CASE (IACT) CASE(0) RESULT = (X(1)-2.0E0)**2 + (X(2)-1.0E0)**2 CASE(1) RESULT = (X(1)-1)**2*(X(1))**2 !CASE(2) !RESULT = -(X(1)**2)/4.0E0 - X(2)**2 + 1.0E0 END SELECT END SUBROUTINE END PROGRAM
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Note that you did not declare or set IBTYPEIt is declared and initialized to zero in the module.
And that is the problem with overuse of modules -- one tends to forget all the stuff put into the module, and it is ever so convenient to say "USE ...." when we no longer remember all the things that are now available. Thank goodness for "USE mymod, only: fork" and "USE mymod, except=>kitchen_sink".
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
MODULE sharedvars IMPLICIT NONE INTEGER :: n, m = 2, me = 1, ibtype = 0 END PROGRAM xnnlpf USE nnlpf_int USE wrrrn_int USE sharedvars IMPLICIT NONE ! REAL fvalue REAL, ALLOCATABLE :: x(:), xguess(:), xlb(:), xub(:) INTEGER i EXTERNAL fcn ! READ (*, *) n ALLOCATE (x(n), xguess(n), xlb(n), xub(n)) xlb = -100 xub = 100 DO i = 1, n xguess(i) = 0.1*i END DO ! CALL nnlpf(fcn, m, me, ibtype, xlb, xub, x) ! CALL wrrrn('The solution is', x) DEALLOCATE (x, xguess, xlb, xub) END SUBROUTINE fcn(x, iact, result, ierr) USE sharedvars IMPLICIT NONE INTEGER iact, i REAL (kind(1E0)) x(n), & ! N is taken from SHAREDVARS result LOGICAL ierr ! SELECT CASE (iact) CASE (0) result = 0 DO i = 1, n result = result + (x(i)+i-3)**2 END DO CASE (1) result = x(1) - 2.0E0*x(2) + 1.0E0 CASE (2) result = -(x(1)**2)/4.0E0 - x(2)**2 + 1.0E0 END SELECT RETURN ENDCompile and run it for various values on n, such as n = 2, n=3, n=4, e
tc.
okay,I have passed the optimization parameter to my FCN as you do . but i have another question here: if i have hundreds of constraints ,for example,500 equalities constraints and 500 unequalities ,with more than 5000 variables,how can i write the FCN? i don't think the "SELECT CASE" structure is a feasible way to do this. so i try the program using the "IF -ELSEIF -END IF" statements like below:
! shuc.f90
! FUNCTIONS:
! shuc - Entry point of console application.
! PROGRAM: shuc
! PURPOSE: Entry point for the console application.
MODULE my_data_type!自定义数据类型,包括机组数据,负荷数据
TYPE:: unit_data
CHARACTER (len=8) :: unit_name
CHARACTER (len=4) :: unit_zone
REAL :: zone_trans_pmax
REAL::unit_pmax,unit_pmin
CHARACTER (len=1) :: unit_type
TYPE(unit_data),POINTER::next_unit_data
END TYPE
TYPE:: load_data
CHARACTER (len=4) :: load_zone
REAL :: peak_load,valley_load,zone_trans_pmax
TYPE(load_data),POINTER::next_load_data
END TYPE
TYPE:: variable
REAL::x
TYPE(variable),POINTER::next_variable
END TYPE
CONTAINS
SUBROUTINE unit_data_add(pos,head,unit_name,unit_zone,zone_trans_pmax,unit_pmax, unit_pmin,unit_type,unit_data_num)
INTEGER::unit_data_num
REAL ::zone_trans_pmax
TYPE(unit_data),POINTER::temp,pos,head
ALLOCATE(temp)
temp%unit_name=unit_name
temp%unit_zone=unit_zone
temp%zone_trans_pmax=zone_trans_pmax
temp%unit_pmax=unit_pmax
temp%unit_pmin=unit_pmin
temp%unit_type=unit_type
NULLIFY(temp%next_unit_data)
IF (.NOT.ASSOCIATED(POS))THEN
ALLOCATE(pos)
pos%unit_name=unit_name
pos%unit_zone=unit_zone
pos%zone_trans_pmax=zone_trans_pmax
pos%unit_pmax=unit_pmax
pos%unit_pmin=unit_pmin
pos%unit_type=unit_type
head=>pos
NULLIFY(pos%next_unit_data)
ELSE
pos%next_unit_data=>temp
pos=>temp
IF( unit_data_num==1) THEN
head%next_unit_data=>pos
END IF
END IF
! DEALLOCATE( temp)
unit_data_num=unit_data_num+1
END SUBROUTINE unit_data_add
SUBROUTINE load_data_add(pos,head,load_zone,peak_load,valley_load,zone_trans_pmax,load_data_num)
INTEGER::load_data_num
REAL::peak_load,valley_load
TYPE(load_data),POINTER::temp,pos,head
ALLOCATE(temp)
temp%load_zone=load_zone
temp%peak_load=peak_load
temp%valley_load=valley_load
NULLIFY(temp%next_load_data)
ALLOCATE(pos)
pos%load_zone=load_zone
pos%peak_load=peak_load
pos%valley_load=valley_load
head=>pos
NULLIFY(pos%next_load_data)
ELSE
pos%next_load_data=>temp
pos=>temp
IF( load_data_num==1) THEN
head%next_load_data=>pos
END IF
END IF
! DEALLOCATE( temp)
load_data_num=load_data_num+1
END SUBROUTINE load_data_add
SUBROUTINE variable_add(pos,head,variable_num)
INTEGER::variable_num
TYPE(variable),POINTER::temp,pos,head
ALLOCATE(temp)
temp%x=1.
NULLIFY(temp%next_variable)
ALLOCATE(pos)
pos%x=1.
head=>pos
NULLIFY(pos%next_variable)
ELSE
pos%next_variable=>temp
pos=>temp
IF( variable_num==1) THEN
head%next_variable=>pos
END IF
END IF
! DEALLOCATE( temp)
variable_num=variable_num+1
END SUBROUTINE variable_add
END MODULE
MODULE read_data
USE my_data_type
CONTAINS
SUBROUTINE read_optimization_para(peak_dc,valley_dc,peak_ac,valley_ac,head_unit,unit_data_num,head_load,load_data_num)
REAL::peak_dc,valley_dc,peak_ac,valley_ac
INTEGER::i,j
CHARACTER(len=1000)::data_str
TYPE(unit_data),POINTER::head_unit,tail_unit,ptr_unit
TYPE(unit_data)::current_unit
LOGICAL::DATA_READING=.FALSE.
INTEGER::result_string_scan=0
REAL::peak_load,valley_load,peak_total_load,valley_total_load
TYPE(load_data),POINTER::head_load,tail_load,ptr_load
INTEGER::size_of_variable
NULLIFY(tail_load)
NULLIFY(head_load)
NULLIFY(head_unit)
NULLIFY(tail_unit)
!NULLIFY(head_variable)
!NULLIFY(tail_variable)
OPEN(UNIT=20,FILE='上海机组小开机.txt',ACTION='READ')
load_data_num=0
unit_data_num=0
DO !读入机组数据
READ(20,'(A)') data_str
result_string_scan=INDEX(data_str,'end_of_unit_data')
IF (result_string_scan/=0)THEN
EXIT
END IF
IF(data_str(1:1)=='.')THEN
CYCLE
ELSE
IF (DATA_READING==.TRUE.)THEN
READ(data_str,*)unit_name,unit_zone,zone_trans_pmax,unit_pmax,unit_pmin,unit_type
CALL unit_data_add(tail_unit,head_unit,unit_name,unit_zone,zone_trans_pmax,unit_pmax, unit_pmin,unit_type,unit_data_num)
ELSE
result_string_scan=INDEX(data_str,'begin_unit_data')
DATA_READING=.TRUE.
END IF
!result_string_scan=INDEX(data_str,'end_of_unit_data')
!IF (result_string_scan/=0)THEN
! DATA_READING=.FALSE.
! EXIT
!END IF
END IF
END IF
END DO
peak_total_load=0
DO !读入分区负荷数据
result_string_scan=INDEX(data_str,'end_of_load_data')
EXIT
END IF
CYCLE
ELSE
READ(data_str,*)load_zone,peak_load,valley_load,zone_trans_pmax
CALL load_data_add(tail_load,head_load,load_zone,peak_load,valley_load,zone_trans_pmax,load_data_num)
peak_total_load=peak_total_load+peak_load
ELSE
result_string_scan=INDEX(data_str,'begin_load_data')
DATA_READING=.TRUE.
END IF
!result_string_scan=INDEX(data_str,'end_of_load_data')
! EXIT
!END IF
END IF
END IF
END DO
DO !读入高峰低谷区外来电数据
result_string_scan=INDEX(data_str,'end_of_power_injection_data')
EXIT
END IF
CYCLE
ELSE
READ(data_str,*)peak_dc,valley_dc,peak_ac,valley_ac
ELSE
result_string_scan=INDEX(data_str,'begin_power_injection_data')
DATA_READING=.TRUE.
END IF
! EXIT
!END IF
END IF
END IF
END DO
CLOSE(20)
END SUBROUTINE read_optimization_para
END MODULE
program shuc
include 'link_fnl_shared.h'
include 'link_fnl_static.h'
use lin_eig_self_int
use lin_sol_svd_int
USE WRRRN_INT
USE NNLPF_INT
USE my_data_type
USE READ_DATA
IMPLICIT NONE
INTEGER::IBTYPE=0
INTEGER::M, ME
!REAL :: zone_trans_pmax
!REAL::unit_pmax,unit_pmin
!CHARACTER (len=1) :: unit_type
INTEGER::variable_num=0
REAL::k=1
REAL::peak_dc,valley_dc,peak_ac,valley_ac!高峰低谷时段区外直流、交流来电
INTEGER,PARAMETER::N=4
!REAL::A(N,N)
!REAL::D(N)
INTEGER::i,j
!CHARACTER(len=1000)::data_str
TYPE(unit_data),POINTER::head_unit,ptr_unit
!TYPE(unit_data)::current_unit
!LOGICAL::DATA_READING=.FALSE.
!INTEGER::result_string_scan=0
!CHARACTER (len=4) :: load_zone
!REAL::peak_load,valley_load,peak_total_load,valley_total_load
TYPE(load_data),POINTER::head_load,ptr_load
!TYPE(variable),POINTER::head_variable,tail_variable
REAL(KIND(1E0)) FVALUE, X(300), XGUESS(300), XLB(300), XUB(300)
EXTERNAL FCN
NULLIFY(ptr_load)
NULLIFY(ptr_unit)
CALL read_optimization_para(peak_dc,valley_dc,peak_ac,valley_ac,head_unit,unit_data_num,head_load,load_data_num)
!ME=2!等式约束两个,分别为整数约束和高峰电力平衡约束
!M=2*load_data_num+ME!总约束为:分区数*2(高峰、低谷分区主变不过载)+ME
!!定义变量列表
!DO i =1,3*unit_data_num
! CALL variable_add(tail_variable,head_variable,variable_num)
!END DO
!size_of_variable=3*unit_data_num
M=2
ME=1
ptr_unit=>head_unit
DO i=1,unit_data_num
XLB(i)=ptr_unit%unit_pmin
XUB(i)=ptr_unit%unit_pmax
ptr_unit=>ptr_unit%next_unit_data
XGUESS(i)=1
XGUESS(i+unit_data_num)=XUB(i)!迭代初始方式为高峰、低谷全开机满发
XGUESS(i+2*unit_data_num)=XUB(i)
END DO
NULLIFY(ptr_unit)
!XLB = -HUGE(X(1))
!XUB = HUGE(X(1))
CALL NNLPF (FCN, M, ME, IBTYPE, XLB, XUB, X,IPRINT=1)
!DO i =1,size(X)
!END DO
pause
end program shuc
SUBROUTINE FCN (X, IACT, RESULT, IERR)
USE READ_DATA
USE my_data_type
INTEGER IACT
LOGICAL IERR
INTEGER::i,j
INTEGER::unit_data_num=0
INTEGER::load_data_num=0
REAL::peak_total_load,valley_total_load
NULLIFY(ptr_load)
NULLIFY(ptr_unit)
peak_total_load=0
valley_total_load=0
ptr_load=>head_load
DO i =1,load_data_num
peak_total_load=peak_total_load+ptr_load%peak_load
valley_total_load=valley_total_load+ptr_load%valley_load
ptr_load=>ptr_load%next_load_data
END DO
variable_num=3*unit_data_num
WRITE(*,*) peak_total_load,peak_ac,peak_dc
IF(IACT==0)THEN!目标函数,低谷本地调峰缺口最小
RESULT=0
RESULT =RESULT+ X(i)*X(i+unit_data_num*2)
END DO
RESULT=RESULT-valley_total_load-valley_ac-valley_dc
ELSEIF(IACT==1)THEN!高峰电力平衡约束
RESULT=0
RESULT =RESULT+ X(i)*X(i+unit_data_num)
END DO
RESULT=RESULT-peak_total_load-peak_ac-peak_dc
ELSEIF(IACT==2)THEN!机组开机状态0-1约束
RESULT=0
RESULT=RESULT+X(i)**2*(1-X(i))**2
END DO
ELSEIF(IACT<=3+load_data_num)THEN !高峰主变过载约束
IF (IACT==3)THEN
ptr_load=>head_load
END IF
RESULT=ptr_load%zone_trans_pmax-ptr_load%peak_load
ptr_unit=>head_unit
DO i =1,unit_data_num
IF (ptr_unit%unit_zone==ptr_load%load_zone)THEN
RESULT=RESULT+X(i+unit_data_num)*X(i)
END IF
END DO
ELSEIF(IACT<=3+2*load_data_num)THEN !低谷主变过载约束
IF (IACT==3)THEN
ptr_load=>head_load
END IF
RESULT=ptr_load%zone_trans_pmax-ptr_load%valley_load
ptr_unit=>head_unit
RESULT=RESULT+X(i+2*unit_data_num)*X(i)
END IF
END DO
END IF
RETURN
END
i don't know if it will work,and there are so many "can't find or open PDB files" when linking ,and the .exe just exit without any results,shown in the following picture.
could you help me again? thanks very much!!
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Ignore the "can't find or open PDB file" messages when you start debugging (not linking). They are not important. I also suggest that if you want to include longer sources, please attach them as .f90 files rather than inserting into the post.
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Your code compiles and links with no errors, but to run it the data file is needed.
Whether you use SELECT constructs or not is up to you. If you can group your constraints into, say, three blocks, with all the constraints in each block being of similar form, you could do something similar to
if (iact.gt.0.and.iact.le.500) then
else if(iact .lt. 1000) then
result = x(iact) - x(iact+400)
else
endif
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
else
endif
i have uploaded my .f90 files and the .txt input files needed to run the program in the attachments.
but it can't get any result in the output cmd window.
i also try the "CALL NNLPF (FCN, M, ME, IBTYPE, XLB, XUB, X,XGUESS,IPRINT=1)" , where i offered my XGUESS as an initial guess of the solution, which i think is helpful to get the right answer,but i get an err as following:
error #6285: There is no matching specific subroutine for this generic subroutine call. [NNLPF]
can you help me? thanks a lot!
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
There are several errors in your program. You have declared several arrays that should be of size N (= the number of variables in the optimization problem) with dimension (300). The IMSL optimization routine obtains N from the size of the array passed to it, so it thinks that N = 300, whereas you want N = 21.
The input bounds must satisfy xlb < xub. You have several variables for which the bounds given satisfy xlb = xub. Do you want those elements of x() to be fixed at the bound values? If so, reformulate the problem by separating variable variables and fixed "variables".
To pass an optional argument in Fortran 90, you have to follow certain rules. To pass XGUESS, you need to write ",XGUESS=XGUESS", using the keyword name.
You should not use the == or .EQ. operators to compare logical expressions. Use .EQV. instead.
Your FCN subroutine is rather long and complicated. Have you checked whether all the components of the objective and constraints are calculated correctly? If not, I suggest that you replace the call to NNLPF with several calls "CALL FCN(xguess,Iact,fvalue,ierr)" with different values of Iact, remove all references to IMSL, and run with runtime checks turned on for uninitialized variables, array bound errors and so forth. I have a suspicion that your linked list of pointers is such that some uninitialized pointers are being dereferenced.
The routine also calls "read_optimization_para" at its beginning, which means that the data file gets read and data structures get initialized hundreds of times. Is this really necessary?
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
i have modified my codes and it can run to an result now,even though the result is not what i think is correct. i guess the possible reason is that the NNLPF routine is not desighed to find global solution.
actually, in my equality contraints below:
ELSEIF(IACT==2)THEN!the 0-1constraints RESULT=0 DO i=1,unit_data_num RESULT=RESULT+X(i)**2*(1-X(i))**2*9999 END DO
i just want my X(1,len(X)/3)={0,1}, that is binaray numbers. but i can't find the routine that can solve optimization problem containing binaray variables in the help document. so can you tell me which routine to use to solve this problem?
thanks very much!
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
supplimentary comments: my equality and unequlity constraints consists of Xi*Xi+unit_num items,where Xi (i>=1 and i<=unit_num )are binary variables(0-1) and Xi+unit_num items(unit_num is a constant) are real numbers. jusu like the following constraints :
X1*X1+unit_num + X2*X2+unit_num +.....+ Xunit_num *Xunit_num +unit_num =constant1
X1*X1+unit_num + X2*X2+unit_num >=constant2
X3*X3+unit_num + X4*X4+unit_num +X5*X5+unit_num >=>=constant3
X6*X6+unit_num + X7*X7+unit_num +X8*X8+unit_num +X9*X9+unit_num +X10*X10+unit_num >=constant4
is there any routine to solve this problem in the IMSL package?
thanks!
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
If you want to do pseudo-boolean variable optimization and/or global optimization, you will have to look elsewhere for suitable algorithms. Consult Prof. Mittelmann's site at http://plato.asu.edu/guide.html .
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
thanks very much!
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
ELSEIF(IACT==2)THEN!the 0-1constraints RESULT=0 DO i=1,unit_data_num RESULT=RESULT+X(i)**2*(1-X(i))**2*9999 END DOi just want my X(1,len(X)/3)={0,1}, that is binaray numbers. but i can't find the routine that can solve optimization problem containing binaray variables in the help document. so can you tell me which routine to use to solve this problem?
thanks very much!
i have another question here that why the indicated result after iteration doesn't meet the 1st equality constraints as shown below?
ELSEIF(IACT==1)THEN!高峰电力平衡约束 RESULT=0 DO i=1,unit_data_num local_p_peak =local_p_peak+ X(i)*X(i+unit_data_num) RESULT =RESULT+ X(i)*X(i+unit_data_num) END DO RESULT=RESULT-peak_total_load+peak_ac+peak_dc thank you again!
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
The IMSL routine gave up on the calculation and returned without any iterations. In fact, it did not even evaluate the object function once before giving up. See this part of the output:
TERMINATION REASON:
STEPSIZESELECTION: NO ACCEPTABLE STEPSIZE IN [SIGSM,SIGLA]
EVALUATIONS OF F 0
EVALUATIONS OF GRAD F 0
EVALUATIONS OF CONSTRAINTS 16535
EVALUATIONS OF GRADS OF CONSTRAINTS 0
I would not be brave enough to try such a large problem without having good starting data. You have set the bounds as (-1,2) for many variables, and the starting value as 1. Are these reasonable? Can you do better? I am not going to be of much help in this part because I have no knowledge of the application area. Do the variables have units (metres, pascals, volts, etc.)?
- Marcar como novo
- Marcador
- Subscrever
- Silenciar
- Destacar
- Imprimir
Do you have a version of the problem with fewer variables and constraints? If so, you may be able to solve that problem first, and use the results from it to generate good starting values for the larger problem.
After thinking and looking at your problem over a few hours, I think that I have found a way to solve it. Here are my thoughts.
You have N = 3 n variables, where n is what you call unit_data_num in the program.Let the unknowns be called X = {u, v, w} where u = X(1:n), v = X(n+1:2n), w = X(2n+1:N). Then, your objective function is
F = uTw + a
and the general constraints are of the form
some(u.*v) >= b, some other(u.*w) >= c
In order to force u to be an array of binary variables you have added the artificial constraint
norm {u.*(1 - u)} = 0
The binary variables are not only going to cause standard continuous optimization methods to have a lot of trouble, but they are also unnecessary!
Use new variables {y, z}, where y = u.*v and z = u.*w, where ".*" stands for element-by-element multiplication, as in Matlab. With these variables, you no longer need the additional constraint, and you have a third fewer variables. The problem that you have implemented in the program may now be recast as a linear programming (LP) problem involving continuous variables only, and could be solved efficiently using an LP solver.
I have attached a file containing the solution that I found (using a modified version of your program, which I have attached also). In the solution file, if a line in the file ends with an 'l', that variable is at the lower bound; if a 'u', it is at the upper bound. Otherwise, the variable is free (bounds not active). You may interpret those variables that are zero to be entities such as "power plant P is on but its output is 0 or power plant P is off but if it had been on then the output would have been 200 MW but not delivered to consumer/customer Q".
- Marcar tópico como novo
- Marcar tópico como lido
- Marcador
- Subscrever
