29650 Discussions
v 9.1 for 64 bit code and 32 bit code
lgchen
Our machine is 64 bit and compiler is 64 bit. The compiler code should be 64 bit automatically or there is some specifications? I am talking about version 9.1 here.
rreis
Quoting - lgchen
with a 64bit compiler in a 64 enviroment it should be 64 bit (assuming by "64 bit machine" a 64 bit Operating System)
TimP
Quoting - lgchen
The Intel compilers don't have a switch to change between 32- and 64-bit. If you are using the "Intel64" or "em64t" compiler (the one normally installed under /opt/intel/fce/ for 9.1) you get 64-bit code. ifort -V will tell you which compiler is active.
