29542 Discussions
yet another bug(?) in parameterized derived types
may_ka
Hi all
I think this code should compile:
Module modparadt
  Type, public :: xx(k)
    Integer, kind :: k
    integer(k), allocatable :: v(:)
  End type xx
End Module modparadt
Program Test
  use modparadt
  Type(xx(8)), pointer :: yy=>null()
end Program Test
but when using ifort 17.07 and ifort 18.03 it stops with
tmp.f90(9): error #6197: An assignment of different structure types is invalid.   [YY]
any comments. If this is a bug I'll launch a ticket pointing to this theard.
cheers
Juergen_R_R
Valued Contributor II
Indeed, this compiles and runs with PGI 18.5, gfortran 9.0.0 (experimental) and nagfor 6.2 without any problems.
FortranFan
I too think it is a bug in Intel Fortran.  And it persists in 19.0 Beta Update 1 as well.
For whatever it's worth, the following change where the initialization of the object in the declaration is replaced with a separate pointer assignment instruction. Intel Fortran compiles the code ok:
  type(xx(k=8)), pointer :: yy
  yy => null()
