Intel® Graphics Performance Analyzers (Intel® GPA)
Improve your game's performance by quickly specifying problem areas
Can't Open capture frame
zcevans
I use GPA to capture frame successfully ,but an error occurred when I open the capture frame.Is there anybody know how to deal with that.
BTW,I tried many versions of GPA (2021.2 2021.3 2021.4),but find the same error.
Pamela_H_Intel
Zc - I think you might be trying to capture a frame from a DX11 app with deferred capture enabled. Deferred capture is not fully implemented for DX11. To check:
  • In Graphics Monitor, before capturing, go into Options (bottom left corner of GM)
  • Click the Stream tab
  • If your app is DX11, you need to have the first toggle set to "off".
