Intel® Graphics Performance Analyzers (Intel® GPA)
Improve your game's performance by quickly specifying problem areas
538 Discussions
Cannot install GPA -- INDE installer fails with error code 1603
hanu_r_
I was using an older version of GPA (2014 R2 I believe) and tried to update to the one in the new INDE package. It uninstalled the old version but the installer of the new version failed immediately with the following:
"Failed to process component: Graphics Frame Analyzer & System Analyzer
Windows Installer failed to configure product:
Error message: The installer has encountered an unexpected error installing this
package. This may indicate a problem with the package. The error code is 1. {{The
arguments are: 2, 3, 4}}
Error code: 1603
File name: gpa_14.3_release_232800_x64_INDE_starter.msi"
I tried launching the gpa_14.3_release_232800_x64_INDE_starter.msi manually from the temp directory and it fails immediately after clicking continue with:
"The installer hass encounted an unexpected error installing this package. This may indicate a problem with this packate. The error code is 2739"
I tried both the online installer and downloading the full install package (w_inde_2015.0.011.exe).
As the installer uninstalled the previous version, and I cannot find the old version for download anywhere anymore I am left with not being able to run GPA at all. So any help would be much appreciated.
Neal_Pierman
Valued Contributor I
Sorry that you are running into this issue.
Can you tell me a little more about the configuration of the system where you are installing the product?
Until we get this straightened out, you can get a copy of the previous version (r2) from this page under "legacy platform support".
thanks!
Neal
Neal_Pierman
One thing that you could do to help us debug this...
Can you please try the install one more time, then look in %temp% and attach a copy of the most recently modified msi*.log file.
thanks!
Neal
Neal_Pierman
Even if you want to stick with R2, could you please let us know what system configuration you have that causes this issue -- right-click on the GPA Monitor and copy the "About..." info here.
Neal
hanu_r_
Hey, sorry for late reply.
Thanks for the R2 link, it is working for now.
System info from R2 is:
Windows 7 build 7601, 64-bit DEP enabled
Num Processors: 8
Memory: 12279MB
System BIOS: American Megatrends Inc. 1402 (03/25/2011)
Video BIOS: Version 80.10.3A.00.2C (07/22/13)
Driver 0:
Device: NVIDIA GeForce GTX 780
Provider: NVIDIA
Date: 10-16-2014
Version: 9.18.13.4448
VendorId: 10de
ProductId: 1004
Stepping: a1
No support for GPA Instrumentation
GPA install directory: C:\util\Intel\INDE\GPA\2014 R2\
GPA version: 14.2.225646
Current user is in Administrators group: YES
Current GPA 2014 R2 (14.2.225646)
Secure Boot/Trusted Boot is Disabled
The machine is a Core i7 930 CPU, 12GB ram, GeForce GTX 780.
[log files removed by Intel]
Neal_Pierman
Thanks for the additional information! I've passed this onto the development team for more analysis.
Neal
siddharth_s_1
I am facing the same issue as @Hanu r.
Here is my system config..
Num Processors: 8
Memory: 8073MB
System BIOS: Dell Inc. A14 (07/11/2012)
Video BIOS: Hardware Version 0.0
Driver 0:
     Device: NVIDIA NVS 4200M
     Provider: NVIDIA
     Date: 1-10-2013
     Version: 9.18.13.1100
     VendorId: 10de
     ProductId: 1056
     Stepping: a1
GPA install directory: C:\Intel\INDE\GPA\2014 R2\
Neal_Pierman
Sorry that you are also running into this issue. From what you're showing, it appears that you were attempting to upgrade from 2014 R2 to INDE -- is this correct?
Also, I'm assuming that you're seeing the same error messages -- could you also include a copy of your install logs for us to look at? If you want you can send them to me via a private message.
Thanks!
Neal
Neal_Pierman
Did some more checking, and I saw other Intel INDE components may be running into a similar issue, so check out these links:
Please let me know if this helps.
Neal
