Intel® Graphics Performance Analyzers (Intel® GPA)
Improve your game's performance by quickly specifying problem areas
GPA 2.0: Get message "Instrumented driver is not installed" when attempting to use GPA
Neal_Pierman
重要分销商 I
7,367 次查看
0 项奖励
1 解答
tedruxpin
新分销商 I
7,369 次查看
Installing the latest BIOS has solved this problem! Thanks to you and your team for the effort!
在原帖中查看解决方案
0 项奖励
25 回复数
tedruxpin
新分销商 I
6,157 次查看
I am trying to get GPA up and running on a new Dell system using the Intel G45/G43 chipset, 3gb RAM, Core 2 Duo 2.80GHz running Windows Vista 32-bit. I have run the Intel Driver Update Utility and verified that my driver version is up to date, 7.15.10.1688 at this time. I start the "Intel GPA Remote Server", then I start the "Intel GPA Frame Capture Tool." When I try to connect locally I get an error message "Instrumented driver is not installed." I have also attempted to connect the Frame Capture Tool from another computer on the network, with the same error.
Any thoughts or suggestions as to what I can try next?
Ted
0 项奖励
Neal_Pierman
重要分销商 I
6,157 次查看
Quoting - tedruxpin
Ted
If you haven't already rebooted since you reloaded the gfx driver and tried running GPA, please reboot again. We've occassionally seen some issues on some systems where GPA may tell you the first time that you run that the instrumented drivers are not loaded, and this message goes away after a reboot (and GPA runs fine from then on).
The next thing I'm going to ask is that you let us know which graphics device you have. For this, you'll need to go into the device manager (by right-clicking "computer" from the start menu), then under "display adaptors" right click on "Mobile Intel 4 Series Express Chipset Family", then Properties, then Details, then Hardware ID's, and let me know what hardware id's you see (should be 4 of them). (BTW, I'm looking to see if I can make this easier for the next version of the code!).
Once we have this info, this will help us ask the next round of questions...
Thanks!
Neal
0 项奖励
tedruxpin
新分销商 I
6,157 次查看
Hello Neal, thank you for responding.
Yes, I did reboot a number of times while trying to get this to work. Including full-off reboots. I also tried restarting all of the tools following a failure and that still didn't solve the problem.
My hardware information is as follows:
Intel G45/G43 Express Chipset
Hardware IDs:
PCIVEN_8086&DEV_2E22&SUBSYS_02831028&REV_03
PCIVEN_8086&DEV_2E22&CC_030000
What's next? Thanks,
Ted
0 项奖励
Neal_Pierman
重要分销商 I
6,157 次查看
Quoting - tedruxpin
Hardware IDs:
Ted
Ted,
BTW, are you running the tools from an Admin or "regular user" account?
Also, can you please check the driver version again? We've also seen some instances where the driver install appears to go ok, but when you reboot the driver ends up not being updated.
And last but not least, does this system have dual graphics? Such as the g45 and a separate gfx card?
Neal
0 项奖励
tedruxpin
新分销商 I
6,157 次查看
Admin account with UAC turned off.
0 项奖励
tedruxpin
新分销商 I
6,157 次查看
Yes, the driver version and hardware ids are the same following a reboot. Actually I reboot after installing drivers as a matter of habit.
No, there are no other video cards installed in the system.
0 项奖励
Neal_Pierman
重要分销商 I
6,157 次查看
Quoting - tedruxpin
The dev team is looking into why this would occur... i'll have some more info tomorrow on this.
regards,
Neal
ps-> initial indications are that for some reason the driver is saying that it doesn't support instrumentation, and we'll try to track down under what circumstances this might occur
0 项奖励
Neal_Pierman
重要分销商 I
6,157 次查看
Quoting:
regards,
Neal
Ted,
Do you have the model number of the machine you are running this on? If so, I can check if we have this in one of our labs and try to duplicate with the 1688 driver.
Also, would you be able to verify that the date on the gfx driver is 3/25/09?
Thanks!
Neal
PS-> I'm also assuming that there aren't any unusual BIOS settings on this machine that specifically mention gfx driver capabilities?
0 项奖励
tedruxpin
新分销商 I
6,157 次查看
Dell Vostro 220, 3gb RAM (800MHz), Intel Core 2 Duo CPU E7400 @ 2.80GHz
Windows Vista Business 32-bit
Driver Date: 3/25/2009
Driver Version: 7.15.10.1688
32mb Dedicated Video Memory
96mb System Video Memory
1166mb Shared System Memory
Single display @ 1920x1200, 32-bit color, 60Hz
Installed drivers: igdumdx32(7.15.10.1688), igd10umd32(7.15.10.1688)
Motherboard Bios version 1.0.3
The only graphics related setting is the boot video device, which is set for the on-board adapter, instead of the PCIx device, which isn't present anyway.
Other than driver and windows updates, and development tools, nothing has been installed on this system that was not default from Dell.
While your team is looking into this, should I try installing older versions of the graphics driver? If so, where can I find them?
Thanks!
0 项奖励
Neal_Pierman
重要分销商 I
6,157 次查看
Ted,
There's an earlier version of the driver available (1637), but it will not work with GPA (you'll get the same "instrumented driver not installed" msg).
However, try starting up the remote server again, then startup the GPA System Analyzer, and when it displays the error message, select "save report", then save this to a file and post that file here on the forum. This will hopefully provide more detailed information that we can use to find out what's happening here.
Thanks!
Neal
0 项奖励
tedruxpin
新分销商 I
6,157 次查看
Hi Neal,
I've attached the System Analyzer report as you requested, I also posted one from last week for the Frame Analyzer. If you need any more information from my side please let me know.
Thanks for continuing to look into this.
Ted
0 项奖励
Neal_Pierman
重要分销商 I
6,157 次查看
Ted,
The development team has created a small utility that I would like you to download and run. This will give us more information regarding your configuration that we'll need in order to be able to diagnose the issues that you are seeing.
If this is ok with you, I'll upload the utility to ftp.intel.com, and send you the info on how to upload and the pwd for it in a separate private msg.
OK?
Neal
0 项奖励
tedruxpin
新分销商 I
6,157 次查看
Sounds good, I'm happy to give it a try. I'll watch for your email.
0 项奖励
Neal_Pierman
重要分销商 I
6,157 次查看
Thanks for trying this out... I've received the output from this utility from you, and have forwarded it to the development team for analysis (though it doesn't look like much, supposedly there's lots of good info in those few characters of output!).
Neal
ps-> Also, I'm assuming that you are running directly on both the client and target machines, and not using "Remote Desktop Connection" to connect to the systems?
0 项奖励
tedruxpin
新分销商 I
6,157 次查看
That is correct, Remote Desktop was not used at any point during my original attempts, or while running the app you provided. I thought I might with this, but I'm trying to keep the system as clean as possible. I am glad to hear that there is more info in the output that was evident.
0 项奖励
Neal_Pierman
重要分销商 I
6,157 次查看
Sorry for not responding more quickly... it ends up that the developer working on this has been away from the office due to illness for the past few days, and is not expected to return until late this week.
Thanks for your patience on this!
Neal
ps-> update as of noon on May 7th; developer is back in the office and is working on this issue
0 项奖励
tedruxpin
新分销商 I
6,157 次查看
Great, I'm glad the individual is feeling better. Thanks for the update!
0 项奖励
Neal_Pierman
重要分销商 I
6,157 次查看
Ok, I just heard back from the driver team, and they are wondering if on your Dell system you have the option of setting a BIOS parameter named MCHBAR? Would you be able to check this and let us know?
thanks!
Neal
0 项奖励
Neal_Pierman
重要分销商 I
6,157 次查看
As an update for those watching this thread, we're doing some more checking on this particular system; we're trying to narrow down whether it's an issue with the system configuration (namely the BIOS parameters), or the graphics driver.
Thanks!
Neal
0 项奖励
Neal_Pierman
重要分销商 I
5,988 次查看
We've been able to acquire one of these systems, and will begin testing shortly to try and duplicate the problem.
Neal
0 项奖励
回复
