Intel® Graphics Performance Analyzers (Intel® GPA)
Improve your game's performance by quickly specifying problem areas
GPA 2012: Frame Analyzer crashes when loading frame capture file
Guay__Jean-Sébastien
Intel GPA 4.3.160275
nVidia GTX 560ti
Intel Xeon W3550 (3.06GHz)
12GB RAM
I captured a frame in a DX11 application and am trying to load it in Frame Analyzer. The load seems to go fine, I start to see the timeline and job tree and can select a job, but then it starts slowing down the entire machine a lot, and eventually pops up a messagebox saying "BEGIN Event was not created." . Click ok on that and another one pops up saying "An unexpected error occurred." and Frame Analyzer crashes.
A colleague of mine has GPA 4.0.something, and can capture the same application and open it in Frame Analyzer fine.
Capturing a frame from DX SDK samples, even DX11 ones, doesn't cause this problem. Capturing the DX9 build of this same application also doesn't cause the problem. We use Compute Shader, however if that was the problem the DX SDK samples that use Compute Shader would also cause the same problem, and they don't.
I tried uninstalling and reinstalling 4.3.160275 but I still get the same results.
This is the XML report that it saves:
Intel GPA Error Report - Please report this error at http://www.intel.com/software/gpa
</p><p>An unexpected error occurred.</p><p>
magic_number: 1095780169
size_of_header: 296
file_revision: 3
entry_count: 27166
target_id: 00000000-0000-0000-0000-000000000000
file_id: c2d7b111-e6b3-443f-9aeb-9f2b79619283
frame: 1007
vendor_id: 4318
device_id: 4608
revision_id: 161
api_version: DX11
driver_version: 8.17.12.9573
sdk_version: 43
process_name: app_d3d11.exe
offset_to_index: 358992929
api_payload_version: 6
offset_to_ShortEntries: 356457939
size_of_ShortEntries: 2534990
number_of_ShortEntries: 6716
Windows 7, 64-bit DEP enabled
Num Processors: 8
Memory: 12279MB
System BIOS: LENOVO 60KT43AUS (04/08/2011)
Video BIOS: Version 70.24.2E.00.60 (09/26/11)
Driver 0:
Device: NVIDIA GeForce GTX 560 Ti
Provider: NVIDIA
Date: 2-9-2012
Version: 8.17.12.9573
VendorId: 10de
ProductId: 1200
Stepping: a1
No support for GPA Instrumentation
GPA install directory: C:\\Program Files\\Intel\\GPA\\4.3\\
GPA version: 4.3.160275
Current user is in Administrators group: YES
Num Processors: 8
Memory: 12279MB
Driver 0:
Provider: NVIDIA
Date: 2-9-2012
VendorId: 10de
ProductId: 1200
Stepping: a1
What can I do to fix this? Thanks in advance.
Seth_S_Intel
Thank you for all the information, this will help us recreate your issue.
Would it be possible to send me the frame you captured when you did not have ID3D11DeviceContext::CopyResource and Map/Unmap methods  commented out?  If I can replicate the crash we will probably be able to fix this issue quicker.
The capture file is rather large, so if you could please private message me a Dropbox (or any other file-sharing service) link with the frame file, we can get this problem fixed.
Seth
Jason_K_3
Hi Seth,
Were you able to get receive the email I sent with the link to the file?
Thanks, Jason
Seth_S_Intel
Hi Jason,
I have not received your email yet.
A good way to private message me is to click on the "Send Author A Message" on this thread.   Then just write your message and I will be notified.
If that doesn't work I'll message you with my email.
Seth
SE2
Hi there. We are having the exact same problem as Jason K. The reported source line and file is the same. Also a DX11 title, but running on Win 10 (though that appears to be unrelated). It would be wonderful if we could get this fixed, the intel performance analyzer has been the only one we've found so far that works with our game at all and we need something dependable to benchmark and trouble shoot this project. Are you in contact with Jason K still at all or did you get his frame capture? I don't think I will be allowed to give you any of our capture files (they all crash on load in the Frame Analyzer). There is nothing sensitive in the error log though, here is ours...
<?xml version="1.0"?>
<Report>
    <Header>
Intel(R) Graphics Performance Analyzers Error Report - Please report this error at http://www.intel.com/software/gpa
</Header>
    <Title>
</Title>
    <Error errClass="8" errCode="13" srcRef="resourcemanager.cpp" srcLine="1170">To load resource of unknown type.<stack></stack></Error>
    <Configuration application="FrameAnalyzer" remoteFile="false">
        <CaptureFileHeader>
size_of_header: 296
file_revision: 3
entry_count: 33703
file_id: 27721652-ac12-493e-b26a-9c396b0d2949
frame: 27989
vendor_id: 4098
device_id: 26685
revision_id: 0
api_version: DX11.1
driver_version: 15.200.1062.1004
sdk_version:
process_name: game_releaseinternal.exe
offset_to_index: 558551349
offset_to_ShortEntries: 558098931
size_of_ShortEntries: 452418
number_of_ShortEntries: 2007
</CaptureFileHeader>
        <Client>
Windows 8.0 build 9200, 64-bit DEP enabled
Num Processors: 4
Memory: 16076MB
System BIOS: American Megatrends Inc. V1.3 (04/13/2012)
Video BIOS: 03/01/12
Driver 0:
     Device: AMD Radeon HD 7700 Series
     Provider: Advanced Micro Devices, Inc.
     Date: 8-3-2015
     Version: 15.200.1062.1004
     VendorId: 1002
     ProductId: 683d
     Stepping: 0
Install directory: C:\Intel\INDE\GPA\2015 R2\
Version: 15.2.247704
</Client>
        <Target>
 DEP enabled
Num Processors: 4
Memory: 16076MB
Driver 0:
     Date: 8-3-2015
     VendorId: 1002
     ProductId: 683d
     Stepping: 0
</Target>
    </Configuration>
    <Details>
    </Details>
    <Description>
</Description>
</Report>
Seth_S_Intel
Hi Skybox Labs,
Sorry to hear Frame Analyzer is crashing for you.    A couple things regarding your issue.
First, we will have full support for windows 10 in our 2015R3 release next week.  So if you are running into any windows related issues, the next release will fix that.
Second,  this bug still exists in GPA.   Jason switched engine versions and the bug appears to not be blocking for him anymore.  I have submitted a bug report in our backlog and have prioritized it high.  Though without a frame file, we can not fix the issue as quickly, but we will try our best. :)
I'll private message you to see if we can work out a solution.
Best,
Seth
