Intel® Graphics Performance Analyzers (Intel® GPA)
Improve your game's performance by quickly specifying problem areas
公告
Intel Wireframe Wallhack crossfire disconnect
PRINCeSsG
初学者
20,215 次查看
please help how to solve such an issue
0 项奖励
17 回复数
Earl_Intel
主持人
20,154 次查看
Hi PRINCeSsG,
Can you clarify a few things with us:
  • When using this "Wallhack" may I know if you're using another application to activate this?
  • Does the issue only happen when you're using "Wallhack"?
  • Can you provide us the game settings that you're using?
  • What Graphics Driver version do you have?
Kindly run this on your system so that I can also gauge the following peripherals and the driver versions that you have:
Intel® System Support Utility for Windows*
Once finished downloading, open the tool, click on scan (leave the default items checked), click next, then save the system information to a .txt file. Please provide us the .txt file.
Earl E.
0 项奖励
PRINCeSsG
初学者
20,118 次查看
That's my settings in the picture when I'm in crossfire, some seconds it came out disconnected from the server but I didn't use wallframe as in normal, when I open it in crossfire the game is ok, I hope it's fine, I just want to play the game on the wall hehehe thank you, I hope it can be fixed
0 项奖励
Earl_Intel
主持人
19,954 次查看
Hello PRINCeSsG,
Thank you for sharing this screenshot with us.
No worries, I will further check on this, kindly provide us also with the SSU logs from your system.
Having the SSU logs will greatly help us investigate the issue you brought up.
Earl E.
0 项奖励
PRINCeSsG
初学者
19,913 次查看
hi good evening, I hope you can solve this problem when you log in to cr0ssf1r3 and then disconnect from the server, please give me a new update
0 项奖励
Earl_Intel
主持人
19,846 次查看
Hello PRINCeSsG,
Thank you for your response.
For us to further investigate on this, we would need to get your SSY logs to further check the driver versions that you have on your system.
Also, may I know the information on the following:
  • If you're not using Wallhack, does CrossFire still crashes?
  • What digital gaming platform did you download CrossFire?
Earl E.
0 项奖励
PRINCeSsG
初学者
19,756 次查看
where can I message you so I can send you a video?
  • Can you provide us the game settings that you're using? = I have sent a picture so you can see what the settings are
  • Does the issue only happen when you're using "Wallhack"? = when I opened cr0ssf1re, after a few minutes he disconnected, I files to attach a picture to the disconnected and settings in intel
  • If you're not using Wallhack, does CrossFire still crashes? = My game is ok with cr0ssf1re, it doesn't crash, it just crashes when I open Graphics Monitor 2020 R1
  • What digital gaming platform did you download CrossFire? = cr0ssf1re PH , You can look at the pictures I files to attach here, all the problems are there
0 项奖励
Earl_Intel
主持人
19,611 次查看
Hello PRINCeSsG,
Thank you for your reply.
I believe you can upload the video directly on the communities.
No worries, I'll further review the screenshots you provided before and will provide you an update on this thread as soon as possible.
Earl E.
0 项奖励
Earl_Intel
主持人
19,568 次查看
Hello PRINCeSsG,
Thank you for patiently waiting.
Just want to clarify a few things:
Earl E.
0 项奖励
PRINCeSsG
初学者
19,472 次查看
How can I contact you? Can I ask for your ID on Facebook so I can chat with you because it's hard to explain here?
Look, I sent you a picture, it crashes and there are only a few options for its shortcut.
0 项奖励
Earl_Intel
主持人
19,386 次查看
Hello PRINCeSsG,
You can upload the video on your GDrive and provide the link in here.
You can also chat us virtually, here is the link on how to contact us via Intel's Virtual Assistant: Contact Intel for Your Support Solutions
Earl E.
0 项奖励
Earl_Intel
主持人
19,137 次查看
Hi PRINCeSsG,
Earl E.
0 项奖励
PRINCeSsG
初学者
18,029 次查看
PRINCeSsG_0-1740493553612.pngThis is an error when I play the game.
PRINCeSsG_1-1740493575688.pngPRINCeSsG_2-1740493595802.pngPRINCeSsG_3-1740493612866.pngThose three pictures are my wallframe settings.
0 项奖励
Earl_Intel
主持人
17,689 次查看
Hello PRINCeSsG,
Thank you for sharing the screenshots.
I'll check on this internally and see what I can do.
I'll provide you an update on this thread as soon as possible.
Earl E.
0 项奖励
Earl_Intel
主持人
17,502 次查看
Hi PRINCeSsG,
Thanks for patiently waiting.
Upon further checking regarding to your concern, seems like this is handled by our Intel Graphics Performance Analyzers.
No worries, I'll be routing your case to them and kindly wait for an update on our team.
Earl E.
0 项奖励
AdmiralSquatbar
初学者
17,300 次查看
I don't have a solution but this post needs an award
0 项奖励
sentientSpark_Intel
16,686 次查看
Thank you for getting us in contact Earl_Intel.
Hi PRINCEsSsG!
I see you are having issues using wireframe overlay in an older release of Intel GPA.
This feature was removed as of release 2021.2 (see here for more information: Wireframe Availability - Intel Community) due to its use in wallhacking sentientSpark_Intel_0-1741025688895.png
If you would like to explore the graphics pipeline used in CrossFire, you can capture a frame using Graphics Monitor and then open it in Frame Analyzer - the Wireframe option is still available there in order to inspect frames.
In regards to your question:
Crossfire might be disconnecting you from the server when Graphics Monitor is attached due to its Anti-Cheat system. We don't have control over what games and applications do when GPA is attached to them.
Thanks for your post!
0 项奖励
christianong
初学者
11,937 次查看
he
0 项奖励
回复
