we've recently moved to Intel 19 Update 3 MPI and noticed that the MPICH_VERSION macro in mpi.h is wrong/confusing on Windows and is also different than on Linux:
2019.3.203/intel64/include/mpi.h:504 (windows)
#define MPICH_VERSION "0.0"
#define MPICH_NUMVERSION 300
on Linux:
#define MPICH_VERSION "3.3b3"
#define MPICH_NUMVERSION 30300103
The latter case is much more reasonable and works fine, while the first case seems to be broken.
In the end, that 3 digit version number makes PETSc assume that it is using an old MPICH version and therefore compares "0.0" with MPI_Get_library_version(), which will eventually fail on Windows.
https://bitbucket.org/petsc/petsc/src/f03f29e6b9f50a9f9419f7d348de13f7c6b76dec/src/sys/objects/pinit.c#lines-807
Can you please fix the version number of windows?
Thank you and kind regards,
Volker Jacht
Thank you for the report, it will be fixed in upcoming release.
Best regards, Yury
