Intel® High Level Design
723 Discussions
About 10bitsPerSymbol of ihc::stream_out
ZXued
I want to use ihc::stream with 10bitsPerSymbol parameter, I defined a interface using:
typedef ihc::stream_out<ac_int<120, false>, ihc::buffer<2>, ihc::readyLatency<1>, ihc::usesPackets<true>, ihc::bitsPerSymbol<10>, ihc::usesEmpty<true>, ihc::firstSymbolInHighOrderBits<true>>  stream_out_pixels;
When compiling, the compiler report following error:
_stream.h:769:54: error: HLS builtin parameter must be a factor of the type size
                   _readyLatency, _bitsPerSymbol,
How can I use 10bitsPerSymbol stream interface.
AnilErinch_A_Intel
Hi ,
As per the compiler pro documentation
ihc::buffer can be used only with the input stream,
Please refer to the compiler pro documentation
https://www.intel.com/content/www/us/en/programmable/documentation/ewa1462824960255.html
for each of the options in the code given and let us know the results.
Thanks and Regards
Anil
ZXued
Thanks for you replay, I remove ihc::buffer on output stream but the problem isn't been solved. I think the result of express "sizeof(ac_int<120, false>)" is not divisible by 10
AnilErinch_A_Intel
Hi ,
Can you try with different ac_int values and lets know , whether the compilation gets successful , when the result is divisible by 10 .
Thanks and Regards
Anil
whitepau_altera
Hi @ZXued
There is currently a restriction on `ihc::bitsPerSymbol` such that symbol widths must be a power of 2. This is a known issue.
