Intel® High Level Design
722 Discussions
Avalon Empty Signal Doesn't Work with oneAPI Simulation
cagxel
I am trying to understand how empty signal is working on Avalon Streaming and I am using slightly modified version of streaming_data_interfaces example on SYCL++_FPGA on Github for this purpose. I get the correct results for emulation but I get constant 0 while I run simulation. Also empty signal is not created on simulation waveform. How can I fix this ?
#include <iostream>
#include <sycl/ext/intel/fpga_extensions.hpp>
#include <sycl/ext/intel/prototype/pipes_ext.hpp>
#include <sycl/sycl.hpp>
#include "exception_handler.hpp"
// limit pixel values to this value, or less
constexpr int kThreshold = 200;
// Forward declare the kernel and pipe names
// (this prevents unwanted name mangling in the optimization report)
class InStream;
class OutStream;
class Threshold;
// StreamingBeat struct enables sideband signals in Avalon streaming interface
using StreamingBeatT = sycl::ext::intel::experimental::StreamingBeat<
    unsigned char,  // type carried over this Avalon streaming interface's data
                    // signal
    true,           // enable startofpacket and endofpacket signals
    true>;         // disable the empty signal
// Pipe properties
using PipePropertiesT = decltype(sycl::ext::oneapi::experimental::properties(
    sycl::ext::intel::experimental::ready_latency<0>,
    sycl::ext::intel::experimental::bits_per_symbol<8>,
    sycl::ext::intel::experimental::uses_valid<true>,
    sycl::ext::intel::experimental::first_symbol_in_high_order_bits<true>,
    sycl::ext::intel::experimental::protocol_avalon_streaming_uses_ready));
// Image streams
using InPixelPipe = sycl::ext::intel::experimental::pipe<
    InStream,        // An identifier for the pipe
    StreamingBeatT,  // The type of data in the pipe
    0,               // The capacity of the pipe
    PipePropertiesT  // Customizable pipe properties
using OutPixelPipe = sycl::ext::intel::experimental::pipe<
    OutStream,       // An identifier for the pipe
// A kernel that thresholds pixel values in an image over a stream. Uses start
// of packet and end of packet signals on the streams to determine the beginning
// and end of the image.
struct ThresholdKernel {
  void operator()() const {
    bool start_of_packet = false;
    bool end_of_packet = false;
    while (!end_of_packet) {
      // Read in next pixel
      StreamingBeatT in_beat = InPixelPipe::read();
      auto pixel = in_beat.data;
      start_of_packet = in_beat.sop;
      end_of_packet = in_beat.eop;
      int empty = in_beat.empty;
      // Threshold
      if (pixel > kThreshold) pixel = kThreshold;
      // Write out result
      StreamingBeatT out_beat(pixel, start_of_packet, end_of_packet,empty);
      OutPixelPipe::write(out_beat);
int main() {
  try {
#if FPGA_SIMULATOR
    auto selector = sycl::ext::intel::fpga_simulator_selector_v;
#elif FPGA_HARDWARE
    auto selector = sycl::ext::intel::fpga_selector_v;
#else  // #if FPGA_EMULATOR
    auto selector = sycl::ext::intel::fpga_emulator_selector_v;
#endif
    sycl::queue q(selector, fpga_tools::exception_handler);
    auto device = q.get_device();
    std::cout << "Running on device: "
              << device.get_info<sycl::info::device::name>().c_str()
              << std::endl;
    // Test image dimensions
    unsigned int width = 16;
    unsigned int height = 16;
    // Generate pixel data
    for (int i = 0; i < (width * height); ++i) {
      bool start_of_packet = (i == 0);
      bool end_of_packet = (i == ((width * height) - 1));
      int empty = i;
      StreamingBeatT in_beat(i, start_of_packet, end_of_packet, empty);
      InPixelPipe::write(q, in_beat);
    // Call the kernel
    q.single_task<Threshold>(ThresholdKernel{});
    // Check that output pixels are below the threshold
    bool passed = true;
    int empty ;
      StreamingBeatT out_beat = OutPixelPipe::read(q);
      passed &= (out_beat.data <= kThreshold);
      empty = out_beat.empty;
      std::cout<<empty<<std::endl;
    std::cout << (passed ? "PASSED" : "FAILED") << std::endl;
    return passed ? EXIT_SUCCESS : EXIT_FAILURE;
  } catch (sycl::exception const &e) {
    // Catches exceptions in the host code
    std::cerr << "Caught a SYCL host exception:\n" << e.what() << "\n";
    std::terminate();
BoonBengT_Altera
Hi @cagxel,
Thank you for posting in Intel community forum, hope all is well and apologies for the delayed in response.
Noted on the example design mention, just to clarify, which quartus version and simulator tool have you installed? Also which hardware that you are trying to simulate on?
And it is correct to say that you are able to successfully build and compile the simulation flow, but running the simulation sample it is not providing the correct result?
If possible could you also share the output result for us to check further?
Hope to hear from you soon.
Best Wishes
BB
cagxel
Hello @BoonBengT_Altera ,
Thanks for your reply.
I am using Quartus Prime, OneAPI version 24.2 and Questa 24.1. I was able to successfully compile and run the simulation as well as emulation, only problem is empty signals are not visible/created on the simulation and values are wrong when I run the executable.
For the emulation, you can see that it prints empty as the same values of "i" as it was assigned on line 96.
However, same code prints constant 0 with simulation.
As you can see, empty signal is not available on waveforms.
I am also including sim.prj file as attachement, please let me know if you need anything else.
Jessica_Intel
Hi @cagxel ,
There is no need for an empty signal, because the data width (8-bit char, defined on line 19 of your code) is equal to the bits_per_symbol (also 8, defined on line 27).
Please refer to the Avalon spec here: https://www.intel.com/content/www/us/en/docs/programmable/683091/22-3/signal-details-78878.html
"The size of the empty signal in bits is ceil[log2(<symbols per cycle>)]."
I hope this helps explain the behavior you're seeing.
Jessica
BoonBengT_Altera
Hi @cagxel ,
Greetings, just checking in to see if there is any further doubts in regards to this matter.
Hope your doubts have been clarified.
Best Wishes
BB
BoonBengT_Altera
Hi @cagxel,
Greetings, as we do not receive any further clarification/updates on the matter, hence would assume challenge are overcome. Please login to ‘ https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions. For new queries, please feel free to open a new thread and we will be right with you. Pleasure having you here.
Best Wishes
BB
