Intel® High Level Design
722 Discussions
DE5a-Net-DDR4 Compilation Problem?
AAlmo
Hey,
l have a DE5a-Net-DDR4 board installed on my system. I’m trying to compile a simple OpenCL code, but always got error message. i double check that all environment settings are correct. The error message displayed after approximately 25 minutes from the starting compilation process. below is a sample output with errors message displayed :
[root@localhost clfiles]# aoc -g -v -fp-relaxed Sobel_lrg1_v11_optm4p.cl -report
aoc: Environment checks are completed successfully.
aoc: Cached files in /var/tmp/aocl/user1 may be used to reduce compilation time
You are now compiling the full flow!!
aoc: Selected default target board de5a_net_ddr4
aoc: Running OpenCL parser....
aoc: OpenCL parser completed successfully.
aoc: Optimizing and doing static analysis of code...
aoc: Linking with IP library ...
Checking if memory usage is larger than 100%
! The report below may be inaccurate. A more comprehensive
! resource usage report can be found at Sobel_lrg1_v11_optm4p/reports/report.html
; Estimated Resource Usage Summary                  ;
; Resource                + Usage           ;
; Logic utilization           ;  50%           ;
; ALUTs                 ;  34%           ;
; Dedicated logic registers       ;  19%           ;
; Memory blocks             ;  34%           ;
; DSP blocks               ;  24%           ;
aoc: First stage compilation completed successfully.
Compiling for FPGA. This process may take a long time, please be patient.
Error (17941): The design could not be loaded due to errors.
Error: design::import_design -file base.qdb -overwrite failed!
Error (23031): Evaluation of Tcl script /home/intelFPGA_pro/17.1/quartus/common/tcl/internal/qatm_import_design.tcl unsuccessful
Error: Quartus Prime Compiler Database Interface was unsuccessful. 3 errors, 4 warnings
Error (23031): Evaluation of Tcl script import_compile.tcl unsuccessful
Error: Quartus Prime Compiler Database Interface was unsuccessful. 1 error, 0 warnings
Error: Compiler Error, not able to generate hardware
Always got this error,
below are ssome environment :
[root@localhost bringup]# which aoc
/home/intelFPGA_pro/17.1/hld/bin/aoc
[root@localhost bringup]# which quartus
/home/intelFPGA_pro/17.1/quartus/bin/quartus
I appreciate If i can get some help to solve this issue. Any suggestions? Is it because of license file is not the right one, l don’t thinks so as it is working if I add -c option.
HRZ
Valued Contributor III
Can you post the full quartus_sh_compile.log file? Furthermore, are you using the 17.1 BSP from this page?
https://www.terasic.com.tw/cgi-bin/page/archive.pl?Language=English&CategoryNo=228&No=1108&PartNo=4
AAlmo
Thanks HRZ for your comments, I have this problem solved through contacted the Intel support department.
below is the solution:
Please download *base.qar* file from the link: http://mail.terasic.com.cn/~wyzhou/base.qar , then replace the *base.qar* file in the DE5ANET_DDR4_OpenCL_BSP_17.1\de5a_net_ddr4\hardware\de5a_net_ddr4 folder with this new one and test your project again
This solved my issue and the compilation process is done successfully.
Thanks again for offering help.
HRZ
So, Terasic's BSP is broken, but instead of updating the BSP on their website, they expect people to waste days trying to figure out what is wrong until they contact their support and get the fix from the support? Or maybe they just realized the BSP they released one year ago is broken?
AAlmo
That is why I share the solution, I tried to solve this problem working for more than three weeks!!!!
note: l tried the latest versions 18.1 but have similar problem.
