Hello community,
I'm using the DSP builder to design the behaviour of my logic which shall be converted to VHDL to use it on my Cyclone IV FPGA board.
I want to use some LUTs and I have a strange behaviour depending on the values of the initialization array (Output value map).
If I initialize it with zeros (neither zeros(10,1) nor zeros(1,10) does work) I get an error while compiling the design:
Error reported by S-function 'mip_control' in 'project_name/Control':
DSP Builder for Intel(R) FPGAs - Advanced Blockset Internal Restriction: 'latency >= 0' in folder::internal::LatencyServicesImpl::getLatency at p4/ip/aion/src/alu_folder/latency_services.cpp:165.
If I initialize it with random numbers (both rand(10,1) and rand(1,10)) it works totally fine. --> resulting latency 3, 93 LUTs, no multipliers or memory bits.
Do you have any ideas or hints what to check or to modify? I've already lost a few days in my master thesis because of that problem :(.
Thanks a lot for any support in advance.
Tobias
I'm using DSP builder for MATLAB2019a and MATLAB2019a
Cyclone IV: EP4CE40F23C6
120MHz clock
0.08 MHz sample rate
no constrain latency
and I have already created some working VHDL files (without LUTs)
If this is a standalone LUT (assuming part of a bigger design) - try bookending the LUT with GPIn and GPOut blocks and drop a SynthesisInfo block. In this case, latency=0 - true lookup table / not registered - and it did build fine in Q18.1 w/ R2019a.
In this case, lut_values is designated as the contents in the LUT block.
From setup .m file:
lut_values = zeros(1,16);
Jeff
