Intel® High Level Design
722 Discussions
Failed install of FPGA tookit
mcordery
I'd already installed the oneAPI base toolkit on my local desktop but wanted to try to do a bit of FPGA development. During he install I got the following message
Unpacking intel-oneapi-intelfpgadpcpp-custom-platforms-quartus20.3-2021.1.1 (2021.1.1) ...
dpkg: error processing archive /tmp/apt-dpkg-install-Djnoun/5-intel-oneapi-intelfpgadpcpp-custom-platforms-quartus20.3-2021.1.1_2021.1.1_amd64.deb (--unpack):
trying to overwrite '/opt/intel/oneapi/intelfpgadpcpp/2021.1.1/env/vars.sh', which is also in package intel-oneapi-intelfpgadpcpp-a10gx-s10sx-2021.1.1 2021.1.1
Selecting previously unselected package intel-oneapi-intelfpgadpcpp-custom-platforms-quartus20.3.
Preparing to unpack .../6-intel-oneapi-intelfpgadpcpp-custom-platforms-quartus20.3_2021.1.1_amd64.deb ...
Unpacking intel-oneapi-intelfpgadpcpp-custom-platforms-quartus20.3 (2021.1.1) ...
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
I followed up with this but still get the same error
mcordery@DESKTOP-J13NI0K:~/kernels/HACCmk$ sudo apt --fix-broken install
Reading package lists... Done
Building dependency tree
Reading state information... Done
Correcting dependencies... Done
The following additional packages will be installed:
The following NEW packages will be installed:
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
6 not fully installed or removed.
Need to get 0 B/6322 B of archives.
After this operation, 77.8 kB of additional disk space will be used.
Do you want to continue? [Y/n] Y
(Reading database ... 355734 files and directories currently installed.)
Preparing to unpack .../intel-oneapi-intelfpgadpcpp-custom-platforms-quartus20.3-2021.1.1_2021.1.1_amd64.deb ...
dpkg: error processing archive /var/cache/apt/archives/intel-oneapi-intelfpgadpcpp-custom-platforms-quartus20.3-2021.1.1_2021.1.1_amd64.deb (--unpack):
mcordery@DESKTOP-J13NI0K:~/kernels/HACCmk$ make
dpcpp -fintelfpga -Xshardware -o HACCmk main.o
aoc: error: Quartus could not be found. Please ensure Intel(R) FPGA Add-on for oneAPI Base Toolkit is installed.
dpcpp: error: fpga compiler command failed with exit code 1 (use -v to see invocation)
Makefile:49: recipe for target 'main' failed
make: *** [main] Error 1
mcordery
Got this fixed, did a reinstall via sudo apt then realized I needed to source an environment var script in /opt/intel/oneapi/intelfpgadpcpp/latest/env/vars.sh
mcordery
