Intel® High Level Design
722 Discussions
How do you integrate the Quartus changes back into the OpenCL Flow?
KTeo1
Assuming we are able to understand and make changes to the RTL generated by the OpenCL flow with Quartus, how do we actually get the changes back into the OpenCL flow? As in how do we generate the AOCX to program the board?
KhaiChein_Y_Intel
Hi KTeo1,
You can make changes in the source file/kernel file only.
KTeo1
Ok. Thanks. So I supposed I can program the FPGA directly? Do I need the host?
DongWang-BJTU
you can replace the bitstream in aocx file by using aocl binedit command.
