Intel® High Level Design
723 Discussions
Issues with the use of the flag "-fintelfpga"
FelipeML
Hello!
We are trying to use the emulator to check the results of an algorithm and we have found that the execution fails when we use the "-fintelfpga" flag.
The running example is a simple "triad" that implements two SYCL queues to heterogeneously perform the C=A+alpha*B operation splitting the computation between the CPU and FPGA. To launch the compilation and execution we use the following script:
#!/bin/bash rm -rf *.o *.d *.out *.mon *.emu *.aocr *.aoco *.prj *.fpga_emu *.a triadd-sycl-gpu source /opt/intel/inteloneapi/setvars.sh > /dev/null   rm triadd-sycl-emu dpcpp src/main.cpp src/kernel.cpp -o triadd-sycl-emu -DFPGA_EMULATOR sleep 1 ./triadd-sycl-emu
Up to this point we don't have any problem and the execution works using the s001-n147 compilation node in interactive mode:
u37462@s001-n147:~/triadd$ ./triadd-sycl-emu Experiment: 32 elements, offload-ratio 0.5 Device: Intel(R) FPGA Emulation Device CPU: Intel(R) Xeon(R) Platinum 8153 CPU @ 2.00GHz   RESULT: 0.000 1.500 3.000 4.500 6.000 7.500 9.000 10.500 12.000 13.500 15.000 16.500 18.000 19.500 21.000 22.500 24.000 25.500 27.000 28.500 30.000 31.500 33.000 34.500 36.000 37.500 39.000 40.500 42.000 43.500 45.000 46.500   CPU: Heterogenous triad correct. Kernel: 1.05579 s Total: 1.05587 s
Then, adding the flag "-fintelfpga" to the compilation, as it is recommended to use in BaseKit-code-samples of the "Get started with the Intel oneAPI Base Toolkit on the DevCloud", there is no compilation error but we get the following execution error at runtime:
u37462@s001-n147:~/triadd$ ./triadd-sycl-emu Experiment: 32 elements, offload-ratio 0.5 Device: Intel(R) FPGA Emulation Device CPU: Intel(R) Xeon(R) Platinum 8153 CPU @ 2.00GHz terminate called after throwing an instance of 'cl::sycl::runtime_error' what(): OpenCL API failed. OpenCL API returns: -42 (CL_INVALID_BINARY) -42 (CL_INVALID_BINARY) Aborted
Looking at the link stages with the "-v" flag, we have seen that the only difference of adding "-fintelfpga" is that the target for “clang-offload-wrapper” changes from “spir64” to “spir64_fpga”. This may be one of the sources of errors we are having when compiling for FPGA.
Also, when we are not in interactive mode and we send the compilation to a queue without "-fintelfpga" we get this permission warning:
/var/spool/torque/mom_priv/epilogue.parallel: line 12: /var/spool/torque/mom_priv/epilogue.d//95-nvdir.epilogue: Permission denied
However, there are no errors when executing.
We would really appreciate any help!
Greetings.
MEIYAN_L_Intel
I am checking internally about the information about the option "-fintelfpga" with the developer.
In the mean time, could you provide me the link as mentioned "adding the flag "-fintelfpga" to the compilation, as it is recommended to use in BaseKit-code-samples of the "Get started with the Intel oneAPI Base Toolkit on the DevCloud"?
FelipeML
Hello!
Thank you for the attention.
The specific example I was referring to was the one in: https://devcloud.intel.com/oneapi/get-started/base-toolkit/
In the Vector-Add example when we do "make fpga_emu -f Makefile.fpga" we are using "-fintelfpga" to compile when we want to use the emulator.
In addition, the -fintelfpga flag to use the emulator is also used in all the examples that use FPGA within the BaseKit-code-samples/DPC++Compiler folder. For example, in "FPGATutorials/BestPractices/double_buffering/" when using "set(EMULATOR_COMPILE_FLAGS"-fintelfpga -DFPGA_EMULATOR")" in the CMakeLists.txt, as well as in all other examples in the "FPGAExampleDesigns/" and "FPGATutorials/" directories.
So I assumed that the use of "-fintelfpga" is necessary to use the emulator.
Regards.
FelipeML
Hi again!
I just found in the documentation a section where it says explicitly that we should "Use the following command to compile for emulation: dpcpp -fintelfpga *.cpp"
https://software.intel.com/en-us/oneapi-programming-guide-offline-compilation-for-fpga
Thank you for your help.
MEIYAN_L_Intel
I had find the an useful link which have provide information for compilation in SYCL:
https://github.com/intel/BaseKit-code-samples/blob/master/DPC%2B%2BCompiler/FPGATutorials/Compilation/compile_flow/README.md
You could find the files directory in Devloud with link below:
https://github.com/intel/BaseKit-code-samples/tree/master/DPC%2B%2BCompiler
I had tried the command but there is some permission denied to view the report.
The permission denied is use to prevent IE from issuing "block content".
FelipeML
Hi all and thanks in advance for any help that you could provide.
It seems that the problem with which I opened this thread is still unsolved, and we have just found a modification that seems to narrow down the problem.
We've been playing with the following code that is one of the examples available in the oneAPI training material:
using namespace sycl;
int main()
range<1> r{SIZE};
#ifdef FPGA_EMULATOR
INTEL::fpga_emulator_selector device_selector;
#else
INTEL::fpga_selector device_selector;
#endif
queue q{device_selector};
queue q_cpu{cpu_selector{}};
buffer<int, 1> a_buf{r};
buffer<int, 1> b_buf{r};
buffer<int, 1> c_buf{r};
// a ---- c --- d
// b __/
q.submit([&](handler& h) {
accessor a(a_buf, h, write_only);
h.parallel_for(r, [=](auto idx) {
a[idx] = idx; });
accessor b(b_buf, h, write_only);
b[idx] = -idx; });
q_cpu.submit([&](handler& h) { //fails with q_cpu, but not with q
accessor a(a_buf, h, read_only);
accessor b(b_buf, h, read_only);
accessor c(c_buf, h, write_only);
c[idx] = a[idx] + b[idx]; });
accessor c(c_buf, h, read_write);
c[idx] += 1; });
}).wait();
std::cout << "DONE.\n";
return 0;
As you can see in the comment of the 3rd kernel submission, submitting in the same code to the FPGA and the CPU at the same time and expecting the runtime to solve the data flow dependencies fails with the following message:
u32284@s001-n081:~/oneTBB/examples/SC20/lab$ dpcpp -fintelfpga vector-add-fpga.cpp -DFPGA_EMULATOR -o vadd.emu
u32284@s001-n081:~/oneTBB/examples/SC20/lab$ ./vadd.emu
what(): Native API failed. Native API returns: -42 (CL_INVALID_BINARY) -42 (CL_INVALID_BINARY)
Aborted
If we change the second kernel so that we avoid submitting to the CPU device, the code does not return:
// change q_cpu.submit()... by this:
host_accessor a(a_buf, read_only);
host_accessor b(b_buf, read_only);
host_accessor c(c_buf, write_only);
for(int idx=0; idx<SIZE;idx++){
And the only way to get it works, as far as we know, is by destroying the host_accessors:
u32284@s001-n081:~/oneTBB/examples/SC20/lab$ dpcpp -fintelfpga vector-add-fpga3.cpp -DFPGA_EMULATOR -o vadd.emu
DONE.
Has this been reported before? Are we doing something wrong or is the compiler/runtime that still needs some improvements?
Thanks once again.
KennyTan_Altera
We are sorry to inform that if this thread had been close from Intel quite a while a go. This thread had been transitioned to community support.
If you would require further support from intel, you will need to open a thread on this.
Kenny
KennyTan_Altera
