Intel® High Level Design
722 Discussions
OpenCL Custom Board porting with Quartus Prime 22.4
BC
Hello, I am porting our already ported Stratix 10 GX custom board from 20.4 to 22.4 (the last offical release for OpenCL for FPGA). Everything was ok except I am receiving "Error board.xml: NO_TOP_LEVEL_BOARD_XML_NODE" in platform designer in opening phase which seems has no adverse effect; I generate HDL and then compile through "aoc" with no error. However, I wonder if some action is to be taken or not. I couldn't find any explanation so far. Thank you for your time Regards Bulent CANDAN
hareesh
can you please share error message screenshots. and share project files if it's possible.
BC
Thank you for your response.
Related to the problem I have found that 22.4 has an added entry "board" to "System Info" tab in Platform Designer for component instantiation which is listed as "missing items".  It is listed with "default" value but seems it is not the expected value and when Platform Designer opens a qsys file it reports "Error board.xml: NO_TOP_LEVEL_BOARD_XML_NODE" error on the Open System dialog window.
As I said aoc compilation completes without any errors.
Is this sound OK to you.
Bulent CANDAN
hareesh
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
hareesh
still if you facing issue please reopen the this case from bellow link
please conform it.
hareesh
BC
Thank you gor your time and follow up.
I am getting this error from System Designer when I want to develop the BSP.  I simply ignore it right now. I have not experienced such or similar error from aoc.
Bülent CANDAN
hareesh
HI,
if you don't mind can you share that project files
hareesh
