Intel® High Level Design
723 Discussions
fpga programs are not running
scali
it seems all my FPGA codes cannot run at the moment on the nodes with Arria 10 OneAPI.
Depending if I directly run on the node (e.g. s001-n090) or through devcloud_login -b A10OAPI walltime=12:00:00 job1.sh I get error messages like:
Error enumerating AFCs: not found
Segmentation fault
or
Error: Could not load board library /opt/intel/inteloneapi/intelfpgadpcpp/latest/board/intel_a10gx_pac/linux64/lib/libintel_opae_mmd.so (error_msg: libMPF.so: cannot open shared object file: No such file or directory)
Failed to dynamically load board MMD /opt/intel/inteloneapi/intelfpgadpcpp/latest/board/intel_a10gx_pac/linux64/lib/libintel_opae_mmd.so
I had similar problems before, but they seemed solved. It seems like there is no hardware attached.
Is it OK to just run:
./executable
or I need to do something first?
Thanks in advance for your help.
DDIAKITE
What is the content of your script job1.sh? Make sure you have set up the environment correctly.
AnilErinch_A_Intel
Hi ,
Please re run your application and let us know whether the issue still persists.
Thanks and Regards
Anil
