Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
CPUID check and CR0 check
interruptrequestpack
Hi all
I'm checking if VMX is supported on the processor and if I'm using paged-protected memory model, and enabling VMX operations.
So this is my asm snippet:
__asm {
mov eax, 1
cpuid
and ecx, 0x20
mov supported, ecx
__asm {
mov eax, cr0
and eax, 0x80000000
mov pgMode, eax
mov eax, cr0
and eax, 1
mov ppMode, eax
__asm {
or cr4, 0x2000
Could it work? (I do checks outside the inline with the boolead values supported, ppMode, pgMode)
Another thing: "ensure that CR4 value supports all the CR4 fixed bits reported inIA_32_VMX_CR4_FIXED" what does it means? (I know what fixed bits are, but how to check the support?)
Thanks!
SergeyKostrov
Valued Contributor II
Hi all
__asm {
mov eax, 1
cpuid
and ecx, 0x20
mov supported, ecx
[SergeyK] Yes, it will work. A value 1 means thatthe CPU supports VMX (Virtual Machine Extensions )
technology.
__asm {
mov eax, cr0
and eax, 0x80000000
mov pgMode, eax
mov eax, cr0
and eax, 1
mov ppMode, eax
[SergeyK] Yes, it will workat priviledge level 0 only. An application cannot read or load the control
registers at priviledge levels 1, 2 and 3, and if executed at these levels an exception
'0xC0000096: Privileged instruction' will be raised.
__asm {
or cr4, 0x2000
Thanks!
SergeyKostrov
There is some support for reading and writing of CRx registers with intrinsic functions declaredin 'intrin.h' header file:
__MACHINEX64(unsigned __int64 __readcr0(void))
__MACHINEX64(unsigned __int64 __readcr2(void))
__MACHINEX64(unsigned __int64 __readcr3(void))
__MACHINEX64(unsigned __int64 __readcr4(void))
__MACHINEX64(unsigned __int64 __readcr8(void))
__MACHINEIA32(unsigned long __readcr0(void))
__MACHINEIA32(unsigned long __readcr2(void))
__MACHINEIA32(unsigned long __readcr3(void))
__MACHINEIA32(unsigned long __readcr4(void))
__MACHINEIA32(unsigned long __readcr8(void))
__MACHINEX64(void __writecr0(unsigned __int64))
__MACHINEX64(void __writecr3(unsigned __int64))
__MACHINEX64(void __writecr4(unsigned __int64))
__MACHINEX64(void __writecr8(unsigned __int64))
__MACHINEIA32(void __writecr0(unsigned))
__MACHINEIA32(void __writecr3(unsigned))
__MACHINEIA32(void __writecr4(unsigned))
__MACHINEIA32(void __writecr8(unsigned))
