Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
1135 Discussions
Difference between L2 cache misses and Bus_Trans_Mem
gokussj9
I have a small doubt as to how to find out the number of main memroy accesses from a performacne counter.
L2 cache misses all access the memory but there is a performance counter Bus_Trans_Mem also.
Can anyone please tell me the difference between them and the better one to estimate the number of memory accesses.
Thank You,
Vaibhav
neni
New Contributor II
bus transcation counter should give you what you are looking for. L2 misses can sometime be 2 mem transcation (if a dirt line need to be evicted for example) and also L2 doesn't count uncacheable access (MMIO for example)
