Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
edx and rdx on 64-bit machine
ivantsou
I have questions regarding the usage of edx and rdx registers on a 64-bit machine. How these two registers relate to each other? For example, if I want to do subtraction:
sub edx, 16
This instruction subtracts 16 from edx, and it seems the value in rdx would also be subtracted by 16. Why?
Also, when I use gdb and try to print out the value inside edx, it always shows "void". Is there a way to see the content inside edx register on 64-bit machine? Any comments or answers are highly appreciated. Thank you in advance!
Best,
Ivan
neni
New Contributor II
edx is the lower 32 bit of rdx, when you do sub edx,16 the lower 32 bits are subtracted by 16, while the upper 32 bit are zeroed
ivantsou
Thank you for the response! What if I do "sub rdx, 16" on a 64-bit machine. Does this keep the value in eax unchange and subtract 16 from rdx?
Ivan
jimdempseyatthecove
Think of
union
struct
__int32 eax;
__int32 padd;
__int64 rax;
}; // eax and rax share same register, eax is low part of that register
*** however
some operations on eax bung up padd (as intended)
This mapping is like
al is to ax, al is to eax, al is to rax
ax is to eax, ax is to rax
eax is to rax
with rax though there are some rules as to what happens to upper bits of 64-bit register
(sign extend)
(zero extend)
(untouched)
(unknown)
Jim Dempsey
