Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
1138 Discussions
How to build serial communication with Intel Galileo ?
PENGSHEN_Y_
char number;
void setup()
Serial.begin(9600);
pinMode(13,OUTPUT);
void loop()
if(Serial.available())
number = Serial.read();
Serial.println(number);
if(number=='A')
{digitalWrite(13,HIGH);}
if(number=='B')
{digitalWrite(13,LOW);}
I want to use bluetooth (control by mobile phone) to control the pin13 LED.
I use HC-06 bluetooth model to do that , the RX of HC-06 is connect to TX of Galileo and TX of HC-06 is connect to RX of Galileo.
However it fail   , I dont know the reason but it sucessful on ARDUINO , I want to find some help
It is successful on laptop to control the LED13 , but i could not use HC-06 to control it  :(
PENGSHEN_Y_
I need some help please QAQ
Derp_K_
Can you check this i used it in my manual robot
#include <SoftwareSerial.h>
SoftwareSerial BT(12, 13);     // RX, TX , pins could be edited
int BluetoothData = 0;
void setup()
                 BT.begin(9600);
void loop() {
      if ( BT.available() )
        BluetoothData = BT.read();
            switch (BluetoothData)
                case 'A' :
                            // Your code here
                break;
                case 'B' :
                            // Your code here
                break;
                case 'C' :
                            // Your code here
                break;
                case 'D' :
                            // Your code here
                break;
           default :
                            // Your code here
             delay (10); // For next data
Derp_K_
PENGSHEN_Y_
Reply #3 :
It successfuly work on Arudino and serial output at Intel Galileo but it not work at HC-06
Reply #4:
Thanks for your help , but my board is not Arudino
