Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
1135 Discussions
Intel(R) SDE 9.0 Release Announcement
AdyT_Intel
There is a new release for Intel® software development emulator (SDE) with support for developing binary instrumentation (pin) tools with SDE services.
It is available here: http://www.intel.com/software/sde.
See the release notes for more details.
Shorty
-code_pattern options are not documented on the command line. What are the options? Says “default none” but if you specify no option, sde aborts.
AdyT_Intel
The code-pattern analysis tool is a generic analysis tools that looks for pre-defined code patterns.
It was designed as a generic tool that we can add more patterns to detect. Currently the only available pattern is the misaligned-branch pattern. It is looking for branch instructions that cross 32 bytes alignment. These are considered as a source for performance problems.
