Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
1135 Discussions
Intel SDE not working (assertion_failed: res=TRUE)
Niko1154
I've been trying to get this Intel SDE to work for quite some time now, and just as I fixed one problem another popped up.
E: [tid:7676] SYSCALL_INSPECTOR: NTDLL module is rebased
A: C:\tmp_proj\sde_jenkins\workspace\pypl-sde-nightly-master\GitSDE-master-9.23.0-39-g1c4e8ff06\pin\Source\pin\base_w\ipc_server_windows.cpp: StartServer: 1283: assertion failed: res == TRUE
NO STACK TRACE AVAILABLE
This is the error it gives me when I try to run the SDE even with a simple command such as : sde.exe -- cmd.exe
After this error I can see the task in task manager but it is suspended and doesn't do anything no matter how long I wait.
I don't know what else to try so I hope someone here can help me.
AdyT_Intel
This looks like an old version of Intel SDE.
Please try using the latest version.
