Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
Is it possible to combine CPUID and Instruction set emulation arguments in Intel SDE?
Petrov__Petar
Running `sde.exe -nhm -bmi1 1 -- TestConsole.exe` command don't take into account the `-bmi1 1` option.
It emulates `nhm` instruction set correctly but doesn't emulate the `bmi1` instruction set.
Is it possible to combine them some other way?
ptp
AdyT_Intel
To control the emulation of the CPUID instruction use the -cpuid_in <file> knob.
The CPUID definition file is written in a certain format.
For you purposes you should take the closest file from the kit in <kit>/misc/cpuid/<chip>/cpuid.def and copy it to a new location.
This file is like a dictionary mapping values of EAX/ECX to their expected results.
Then you can edit the certain bits you need, and specify this file to SDE.
This will become something like:
> sde -hsw -cpuid_in <mycpuid.def> -- app
You still need the HSW knob to allow executing the BMI instructions.
AdyT_Intel
No exactly, the -nhm knob instructs SDE to ensure that the application use NHM ISA and that the CPUID instruction behaves as in NHM CPU.
Since the instruction compliance checks for NHM does not include BMI, you will need to either use a CPU that supports BMI (like HSW) or disable chip-check.
It you need to update emulation of the CPUID instruction to include BMI, then we have a way to do it.
Petrov__Petar
Thank you for the quick reply. I am developing a C# wrapper around SDE executable for testing purposes. My main goal is to be able to run some code with specific instruction sets.
How can i update emulation of the CPUID or can i define my CPUID with custom instruction sets?
AdyT_Intel
