- Contrassegnare come Nuovo
- Preferito
- Iscriversi
- Disattiva notifiche
- Iscriversi a feed RSS
- Evidenziare
- Stampare
- Segnalare contenuto inappropriato
- Tag:
- Intel® Advanced Vector Extensions (Intel® AVX)
- Intel® Streaming SIMD Extensions
- Parallel Computing
Link copiato
- « Precedente
- 1
- 2
- Successivo »
- Preferito
- Iscriversi
- Evidenziare
- Stampare
- Preferito
- Iscriversi
- Evidenziare
- Stampare
- Preferito
- Iscriversi
- Evidenziare
- Stampare
- Preferito
- Iscriversi
- Evidenziare
- Stampare
All SDE kits supports both 32 and 64 bit applications. You can use the same sde.exe (on Windows) for both.
But SDE no longer support Windows XP, you should use Windows 7 or newer.
- Preferito
- Iscriversi
- Evidenziare
- Stampare
- Preferito
- Iscriversi
- Evidenziare
- Stampare
- Preferito
- Iscriversi
- Evidenziare
- Stampare
Hi
What is not working for you on 32bits Windows?
Can you please write the error you see or attach a print screen?
Michael
- Preferito
- Iscriversi
- Evidenziare
- Stampare
- Preferito
- Iscriversi
- Evidenziare
- Stampare
Hi
I am indeed SDE developer.
We are running sde.exe version 7.49 on Windows 7 32 bits and it works well.
Can you please send me the screen shot of the error you are seeing?
are you running command line or Cygwin?
Michael
- Preferito
- Iscriversi
- Evidenziare
- Stampare
- Preferito
- Iscriversi
- Evidenziare
- Stampare
- Preferito
- Iscriversi
- Evidenziare
- Stampare
Hi
As we already told you before:We do not support Windows XP at all.
Please upgrade to Windows 7/8/10
Michael
- Preferito
- Iscriversi
- Evidenziare
- Stampare
- Preferito
- Iscriversi
- Evidenziare
- Stampare
- Preferito
- Iscriversi
- Evidenziare
- Stampare
Sergey, I'm not sure what you're trying to accomplish with these posts. You've been told that SDE (the newer versions of it) do not support Windows XP (32 or 64-bit). Obviously, this won't change, and no screenshots from XP will change that. If you want to keep using XP then you'll have to stick with the older versions of SDE as well, with all the consequences.
If you have problems in 32-bit Windows 7 or later, as your initial post and the title suggests, then I think it would be beneficial to post screenshots from Windows 7.
PS: Also, the tone of your messages is certainly not helpful. You may not like that your platform is no longer supported, but that is hardly unexpected for a platform that has long reached EOL. You can't expect it to be supported forever.
- Preferito
- Iscriversi
- Evidenziare
- Stampare
- Preferito
- Iscriversi
- Evidenziare
- Stampare
Just to be clear, I'm not an "Intel guy", and I was not trying to escalate or humiliate anyone.
- Preferito
- Iscriversi
- Evidenziare
- Stampare
- Preferito
- Iscriversi
- Evidenziare
- Stampare
- Preferito
- Iscriversi
- Evidenziare
- Stampare
- Contrassegnare la discussione come nuova
- Contrassegnare la discussione come letta
- Sposta questo Discussione per l'utente corrente
- Preferito
- Iscriversi
- Pagina in versione di stampa
- « Precedente
- 1
- 2
- Successivo »
