Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
SSE runtime comparison (gcc 4.6.1)
debasish83
初学者
1,298 次查看
I was trying these two code snippets. My arrays are all 16 byte aligned:
inline void vecDotSSE(double * s, double * x, double * y, int n)
int ii;
__m128d XMM0 = _mm_setzero_pd();
__m128d XMM1 = _mm_setzero_pd();
__m128d XMM2, XMM3, XMM4, XMM5;
for (ii = 0;ii < (n);ii += 4)
XMM2 = _mm_load_pd((x)+ii);
XMM3 = _mm_load_pd((x)+ii+2);
XMM4 = _mm_load_pd((y)+ii);
XMM5 = _mm_load_pd((y)+ii+2);
XMM2 = _mm_mul_pd(XMM2, XMM4);
XMM3 = _mm_mul_pd(XMM3, XMM5);
XMM0 = _mm_add_pd(XMM0, XMM2);
XMM1 = _mm_add_pd(XMM1, XMM3);
XMM0 = _mm_add_pd(XMM0, XMM1);
XMM1 = _mm_shuffle_pd(XMM0, XMM0, _MM_SHUFFLE2(1, 1));
_mm_store_sd((s), XMM0);
inline void vecDot(double * s, double * x, double * y, int n)
int i;
*s = 0.;
for (i = 0;i < n;++i)
*s += x * y;
My compile flags:
g++ -Wall -O3 -msse3
These are my runtime numbers on vector of size 1M
SSE : 0.0263s
Non-SSE : 1.87996e-07
Does that even make sense ??
I have seen lot of people on the web complaining about the same problem. I will be trying BLAS from ATLAS and Intel MKL as well for SSE blas runtimes.
Did you guys do something on the FPU performance on the new processors ? Seems FPU are much faster than SSE arithmetic cores.
Deb
0 项奖励
6 回复数
debasish83
初学者
1,298 次查看
I think I understood what's going on. SSE version is not inlined by GCC why non-SSE version is inlined !
Although when I tried not to inline both of them (took the inline out from both the code) then I am noticing comparable runtimes. Unfortunately I am still not noticing good speedup in the SSE code.
I am trying the embree-1.0beta code from Intel. I will update the results from that experiment.
Deb
0 项奖励
debasish83
初学者
1,298 次查看
Respective assembly:
vecDotSSE ASM:
.cfi_startproc
xorpd %xmm2, %xmm2
testl %ecx, %ecx
movapd %xmm2, %xmm3
jle .L11
subl $1, %ecx
xorl %eax, %eax
shrl $2, %ecx
mov %ecx, %ecx
addq $1, %rcx
salq $5, %rcx
.p2align 4,,10
.p2align 3
.L12:
movapd (%rsi,%rax), %xmm1
movapd 16(%rsi,%rax), %xmm0
mulpd (%rdx,%rax), %xmm1
mulpd 16(%rdx,%rax), %xmm0
addq $32, %rax
cmpq %rcx, %rax
addpd %xmm1, %xmm3
addpd %xmm0, %xmm2
jne .L12
.L11:
addpd %xmm3, %xmm2
movapd %xmm2, %xmm0
unpckhpd %xmm2, %xmm0
addpd %xmm2, %xmm0
movlpd %xmm0, (%rdi)
ret
.cfi_endproc
vecDot asm:
.cfi_startproc
xorl %r8d, %r8d
testl %ecx, %ecx
movq %r8, (%rdi)
jle .L15
subl $1, %ecx
movq %r8, -8(%rsp)
xorl %eax, %eax
leaq 8(,%rcx,8), %rcx
movsd -8(%rsp), %xmm1
.p2align 4,,10
.p2align 3
.L17:
movsd (%rsi,%rax), %xmm0
mulsd (%rdx,%rax), %xmm0
addq $8, %rax
cmpq %rcx, %rax
addsd %xmm0, %xmm1
movsd %xmm1, (%rdi)
jne .L17
.L15:
rep
ret
.cfi_endproc
It seems to me that gcc -O3 is also using SSE optimization. There are all mmx registers inside vecDot code as well !
I will understand the assembly and figure out why the SSE code is behaving badly.
0 项奖励
TimP
名誉分销商 III
1,298 次查看
You would require -ffast-math to include sum reduction vectorization. Gcc ought to handle this quite well. gcc 4.6 has cleaned up the list of aggressive optimizations under fast-math, so it's safer than similar optimization with icc or older gcc. If the compiler doesn't automatically perform scalar replacement on *s (it should, if you use __restrict pointers), it's simple enough to write that in your source code.
As for a ridiculously short time; if the compiler can see that you never use the result of a loop, it may optimize it away. This kind of benchmark cheating optimization has been in high demand for decades.
0 项奖励
debasish83
初学者
1,298 次查看
Thanks Tim for the quick response. Now I am printing the results as well so that compiler can't cheat.
If I use the following compile flag : g++ -Wall -O3 -msse3
SSE version : 2.38
Non-SSE version : 3.99
So there is clearly 30-40% gain.
Now I added the -ffast-math option. Compile flag : g++ -Wall -O3 -msse3 -ffast-math
SSE version : 2.41
Non-SSE version : 2.49
If I look into the assembly the function body for Non-SSE version looks very similar.
Using this option, is now gcc also loop unrolling the non-SSE code?
Although the asm of the non-SSE function does not look very different than the non -ffast-math version.
.cfi_startproc
xorl %r8d, %r8d
testl %ecx, %ecx
movq %r8, (%rdi)
jle .L15
subl $1, %ecx
movq %r8, -8(%rsp)
xorl %eax, %eax
.p2align 4,,10
.p2align 3
.L17:
addq $8, %rax
cmpq %rcx, %rax
addsd %xmm0, %xmm1
movsd %xmm1, (%rdi)
jne .L17
.L15:
rep
ret
.cfi_endproc
0 项奖励
debasish83
初学者
1,298 次查看
Hi Tim,
This -ffast-math is definitely making non-SSE code comparable to SSE. Can you please let me know what exactly in the -ffast-math that's helping the scalar code??
Deb
0 项奖励
TimP
名誉分销商 III
1,298 次查看
I was assuming you were compiling with SSE option and asking gcc to vectorize (-O3). With -ffast-math -O3, gcc includes auto-vectorization of reductions such as you posted, so you would get within 60% of best possible performance for the loop, without changing your C source code. gcc options -ftree-vectorizer-verbose=n (n >=1) will give you some vectorization diagnostics.
This is equivalent to -fast or #pragma simd reduction() auto-vectorization of icc, with respect to the source code you posted, except that icc will unroll more aggressively to get more performance in the middle range (loop length 100-2000).
0 项奖励
回复
