Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
cache adressed
RBato
How can i adressed to cache memory from assembler level ?
gaston-hillar
Valued Contributor I
Hi Rafal,
After you read the articles mentioned in the responses for the other thread you created with your question about cache memories, I think you will understand how the different cache levels work.
