Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
encoding of AVX10.2 VGETEXPPBF16
Beulich__Jan
VGETEXPP{S,D} are in opcode map 2 (0F38). Correspondingly VGETEXPPH is in opcode map 6. Is it really the case that, as spec version 001 is saying, VGETEXPPBF16 is in map 5, rather than in map 6? After all other insns having a "PH" counterpart share opcode map and major opcode with that, differring in just the (embedded) prefix.
Beulich__Jan
Doc rev 002 addresses this issue, thanks.
Beulich__Jan
