when I run xed command, it shows to me:
xed: /usr/lib/libstdc++.so.6: version `GLIBCXX_3.4.9' not found (required by xed)
seems some compatible 32 bit rpm isn't on my Redhat 5.0 x64 system.
also I can't find any rpm termed compat-libstdc++ 3.4.9 version.
thanks.
any solution on this?
1 解決方案
Hi, you can try to run the "xed.sh" script that exists in the top level of the kit. This script attempts to set the LD_LIBRARY_PATH to the directory in the Intel SDE kit where the linux runtime libraries exist.
Let me know if that works for you (or not).
Mark
連結已複製
3 回應
Mark
