Intel® ISA Extensions
Use hardware-based isolation and memory encryption to provide more code protection in your solutions.
help on xed in avx package
jnzhoun
when I run xed command, it shows to me:
xed: /usr/lib/libstdc++.so.6: version `GLIBCXX_3.4.9' not found (required by xed)
seems some compatible 32 bit rpm isn't on my Redhat 5.0 x64 system.
also I can't find any rpm termed compat-libstdc++ 3.4.9 version.
thanks.
any solution on this?
MarkC_Intel
Hi, you can try to run the "xed.sh" script that exists in the top level of the kit. This script attempts to set the LD_LIBRARY_PATH to the directory in the Intel SDE kit where the linux runtime libraries exist.
Let me know if that works for you (or not).
Mark
MarkC_Intel
Mark
jnzhoun
Yes, it works. thanks you. :)
btw, in the old version of SDE, there isn't a xed.sh but a xed.
it has in new version.
smith001
If you had solved this problem so please send the solution to me because I am also having same problem.
free movies to watch
