3 input DMIP node
Kishor_D_
I want to derive a node a node that takes 3 input images and gives one output image. There is no in-built node present in DMIP library. So, I derived a SimpleNode_3_1 from "Node" class to take 3 inputs. But following trace messages are printed in trace file. Is this approach is correct? or we can't derive a node that takes 3 input nodes.
Trace to file Trace3node.txt started
Image 0012FE60 is being created with not good for DMIP buffer.
Image 0012FDB4 creation failed with code -1
Input port 0 does not exist in SimpleNode_3_1 02424E90 in iGraph 022ECB88
Input port 1 does not exist in SimpleNode_3_1 02424E90 in iGraph 022ECB88
Input port 2 does not exist in SimpleNode_3_1 02424E90 in iGraph 022ECB88
Output port 0 does not exist in SimpleNode_3_1 02424E90 in iGraph 022ECB88
Compilation aborted - free input in Graph 02424E30
Execution aborted - wrong status Normal of Graph 02424E30
Is it explicitely required to specify Input ports (Input port 0, port1 ,port2) and output port? If yes, then how do we specify them?
Kishor_D_
DMIP is still under development stage. The above functionality is still under scrutiny.
Kishor_D_
