64-bit issue: fail to read Jpeg
tom2011
When I am testing some projects from image-codecs sample package, I found the small program ijgtiming fails to work for 64-bit application.
(it works very well for a 32 -bit application )
The program will exit at the 38th line of the source code file jcapimin.c
if (structsize != SIZEOF(struct jpeg_compress_struct))
ERREXIT2(cinfo, JERR_BAD_STRUCT_SIZE,
(int) SIZEOF(struct jpeg_compress_struct), (int) structsize);
Please give me some hints how to fix this bug.
Tom
tom2011
By the way, I am using IPP 7.0
Sergey_Ryadno
Hi tom,
can you share more details about this issue? it apperes when you useijgtiming builded with Maikefiles or through Visual Studio project?
by the way, try this fix in jconfig.h in line 30:
change
[bash]#ifdef WIN32[/bash]
to
[bash]#if defined (WIN32) || defined (WIN64)[/bash]
Naveen_G_Intel
Hi Tom,
Above suggestion is works for you?
Naveen Gv
