Automatic Contrast Adjustment
SharathKum_D_Intel
Hello All,
I am trying to perform Auto Contrast in my grey images using Intel IPP functions. I am not sure where I am going wrong but the image becomes too dark. Here is the code.
#define GrayLevels 256
 int  main()
      std::string path("C:\\sharath\\Images\\");
      std::string inputImageFile = path + "DiffFing.bmp";
       IppImage<Ipp8u,1> imgsrc;
      ippiLoadBMP(inputImageFile.c_str(),imgsrc);
      IppImage<Ipp8u,1> imgDst;
      IppiSize imgSize;
      Ipp32s imgLevels[GrayLevels+1], imgHist[GrayLevels];
      Ipp32s imgValues[GrayLevels];
       int w = imgsrc.Width();
      int h = imgsrc.Height();
      int nlevels = GrayLevels;
      float ww=0;
      int min=0;
      int max=GrayLevels-1;
      int slope;
      float cut_low = 0.05f;
      float cut_high = 0.95f;
       imgSize.width = w;
      imgSize.height = h;
      ippiHistogramEven(imgsrc, imgSize, imgHist, imgLevels, GrayLevels+1, 0, GrayLevels);
       while(ww<cut_low)
            ww+=imgHist[min++];
      while(ww<cut_high)
            ww+=imgHist[max--];
       slope = (GrayLevels-1)/(max-min);
     for(int i=0;i<GrayLevels;i++)
            if(i<=min)
                  imgValues = 0;
            else if(i>=max)
                  imgValues = GrayLevels-1;
            else
                  imgValues = slope*(i-min);
      imgDst.ResizeNE(imgsrc.Width(),imgsrc.Height());
       ippiLUT(imgsrc, imgDst, imgSize, imgValues, imgLevels, GrayLevels+1);
       std::string out4f = path + "DiffFing_Auto.bmp";
      ippiSaveBMP(out4f.c_str(),imgDst);
       return(EXIT_SUCCESS);
 Can somebody help me figure out why my image gets darker instead of enhancing the contrast.
I have also attached the files for reference. DiffFing_AutoContrast.bmp is the image after autocontrast.
Sharath
Thomas_Jensen1
In the while-statement,
    while(ww<cut_low)
            ww+=imgHist[min++];
If I'm not mistaken, there is an error in datatype; ww is accumulating 32s values from imgHist, but cut_low is expressed in percentile, so a proper way would be to first compute the sum of all imgHist bins as 64u, and then have ww also as 64u, with value computed from sum*percentile.
SergeyKostrov
Valued Contributor II
Speaking about corrected image ( difffing-autocontrast.bmp ) it looks good. My question is what Contrast value do you set in case of Auto Contrast correction? For example, if contrast is set to 25% the resulting image will be too pale ( details are lost ), and if contrast is set to 75% the resulting image will be darker and this is what you have.
