hidden text to trigger early load of fonts ПродукцияПродукцияПродукцияПродукция Các sản phẩmCác sản phẩmCác sản phẩmCác sản phẩm المنتجاتالمنتجاتالمنتجاتالمنتجات מוצריםמוצריםמוצריםמוצרים
BGRtoLAB wrong formula specified?
Loos__Stefan
初學者
1,037 檢視
HI
I have a question about the function BGRtoLAB
for LAB, there is a case condition specified in the Manual:
L = 903.3 * (Y/Yn)1/3. for Y/Yn 0.008856
Now, if I take the border case ,  0.008856^(1/3) is ~0.207,   ->  mult  903.3   = ~187
This value is converted to range of 0..255 by factor 2.55, so we get 476 which is way out of range.
Actually i run into this condition (Y/Yn 0.008856) for values like  R=0, G=0, B=10 which is pretty dark, L should be Close to 0 also
So what is wrong with your formulas?
thx & BR
Stefan
0 積分
6 回應
Loos__Stefan
初學者
1,037 檢視
Hi again
found some other formulas. I think it should be without Exponent ^(1/3) like in the f(t) formulas:
L = 903.3 * (Y/Yn). for Y/Yn ≤ 0.008856
as 903 is the factor 7.787*116
Jing_Xu
員工
1,037 檢視
Thank you for reporting the issue,
We will investigate it.
Loos__Stefan
初學者
1,037 檢視
Yes, have a look. the code is ok, the results are ok of the ipp, just the doku
also in the f(t) formula something is wrong, as f(t) is around ~1 you probably won´t substract 16 and multiply later the result .... . It´s all messed up
Jing_Xu
員工
1,037 檢視
What is "doku"? Besides, what does "the code is ok, the results are ok of the ipp" mean? Your program works OK with the IPP function BGRtoLab?
Is this a “theoretical” question? Or could you provide us with a test image and a sample code that can reproduce the problem that you encountered, please?
Loos__Stefan
初學者
1,037 檢視
Yes, the code works, the results are ok
only the documentation (docu, doku) is horribly wrong (the named formulas)
BR
Jing_Xu
員工
1,037 檢視
OK. Got it. Thank you for reporting the issue.
回覆
