Building IPP Samples - CMake issue
BRIAN_F_Intel1
I'm trying to build the IPP Samples, with command
perl build.pl --cmake=speech-codecs,ia32,make,s,st,debug --build --comp=intel
and am getting some cmake errors.
Currently running on Debian (kernel 2.6.32) with CMake 2.8.10.1.
Console output is attached. Has anyone had any CMake errors like this?
Brian
SergeyKostrov
Valued Contributor II
>>I'm trying to build the IPP Samples... ...on Debian (kernel 2.6.32) with CMake 2.8.10.1... >>... >>CMake Error: Could not open file for write in copy operation /CMakeCCompiler.cmake.tmp >>CMake Error: : System Error: Permission denied >>... This is access rights related issue on your computer and it is not related to IPP.
SergeyKostrov
>>CMake Error at /usr/share/cmake-2.8/Modules/CMakeTestCCompiler.cmake:36 (TRY_COMPILE): >> Unknown extension ".c" for file >> >> /media/shared/ipp_samples/ipp-samples.7.1.1.013/__cmake/speech-codecs. >>ia32.make.s.st.debug/CMakeFiles/CMakeTmp/testCCompiler.c >> >> try_compile() works only for enabled languages. Currently these are: >> >> C CXX There is a strange contrudiction since 'testCCompiler.c' is the C-language file. Could you check a line 36 in the 'cmake' file?
BRIAN_F_Intel1
>> /media/shared/ipp_samples/ipp-samples.7.1.1.013/__cmake/speech-codecs.ia32.make.s.st.debug/CMakeFiles/CMakeTmp/testCCompiler.c
>> C CXX
Hi Sergey, I have just (in the last hour) solved this issue. The first issue was user rights as you pointed out. Then I solved the cmake issues but completely uninstalling cmake from my system, then building and installing the latest cmake source. I am now in the process of trying to build the usc_speech_codec binary with static linking...
SergeyKostrov
Hi, >>I have just (in the last hour) solved this issue. The first issue was user rights as you pointed out. Then I solved the cmake issues but >>completely uninstalling cmake from my system, then building and installing the latest cmake source. Thanks for the update.
